Can you recommend a (free) Development Environment for the Cortex M4 on Windows?
Dear @SimonNu
There’s various options, just to list a few:
All free solutions I’m aware of are based on the GNU toolchain (cmake / gcc / gdb), so you will have to install these tools first.
Use the GNU toolchain (cmake / gcc / gdb) on the command line. This is the easiest to setup, but of course does not offer any interactivity e.g. for debgging.
Configure Eclipse to use the GNU toolchain.
There are several tutorials around, such as:
– Tutorial: Building FreeRTOS Applications for ARM Cortex-M4 on i.MX7 with Eclipse
– GPIO example using Eclipse -
Use Visual Studio Code
Actually a good light-weight variant. I tested this successfully, but don’t have any tutorial ready yet. If you want to go this route, I can give you at least some guidelines.
Regards, Andy
