Alsa plugin as a device for colibri imx6
Deer Sir,
I’am trying to write an alsa plugin on colibri imx6 so I edited /etc/asound.conf and here is my code:
pcm.card10 {
type plug
slave.pcm "hw:0,0"
Now I should see my virtual hardware with aplay -L as I can see it with same procedure in ubuntu X86 but nothing appears there; This is the output of aplay -L on imx6:
> default:CARD=imx6colibrisgtl
> imx6-colibri-sgtl5000,
>     Default Audio Device sysdefault:CARD=imx6colibrisgtl
Also I can play a wav file in terminal with this command on imx6 card10:
aplay -vvv sample.wav -D card10
My final purpose is to find my plugin id in pjsua and play some voice with it but I cant find card10 as a device with the code and respective output in this file:
myCode
Hi @amin ,
Can you please specify your BSP version?
Hi @Amin,
Please provide more information about your environment, as the BSP you are using.
Regarding your issue, I think that the problem may be the ALSA itself.
You can check your sound devices by using cat /proc/asound/cards.
See here my example on an Apalis iMX6:
root@apalis-imx6:~# cat /proc/asound/cards
 0 [imx6qapalissgtl]: imx6q-apalis-sg - imx6q-apalis-sgtl5000
 1 [imxhdmisoc     ]: imx-hdmi-soc - imx-hdmi-soc
                      imx-hdmi-soc
 2 [imxspdif       ]: imx-spdif - imx-spdif
                      imx-spdif
The same is informed through aplay -l:
root@apalis-imx6:~# aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: imx6qapalissgtl [imx6q-apalis-sgtl5000], device 0: HiFi sgtl5000-0 []
  Subdevices: 1/1
  Subdevice #0: subdevice #0
card 1: imxhdmisoc [imx-hdmi-soc], device 0: i.MX HDMI Audio Tx i2s-hifi-0 []
  Subdevices: 1/1
card 2: imxspdif [imx-spdif], device 0: S/PDIF PCM snd-soc-dummy-dai-0 [S/PDIF PCM snd-soc-dummy-dai-0]
  Subdevices: 1/1
And, then, you can use the card ID as a reference in your code, according to the ALSA API.
André Curvello
I’am using Toradex Bsp 2.8b7
I found the solution and you are right the problem was Alsa it self; As I mentioned above when I ran the command below on terminal I couldn’t see the plugs and other devices.
aplay -L
I found the answer here link
Ans simply added these two lines in /etc/asound.conf
defaults.namehint.showall on
defaults.namehint.extended on
Now aplay -L show my plug and I can use it in pjsip
Thanks for your replies @andrecurvello.tx @daniel_m.tx
Hi @amin
Perfect that you found the solution. Thanks for your feedback.
