I have followed below steps to flash
Below Commands I have executed in u-boot
- run setusbupdate
- run update
[upload|+Fs/GVcigIGsarIfaa8Y0eiqvKQ=]
Colibri T20 # run update
NAND read: device 0 offset 0x300000, size 0x64
100 bytes read: OK
crc32 for 02000008 ... 0200000a ==> 108dd209 != 94305232 ** ERROR **
NAND read: device 0 offset 0x15c0000, size 0x40
64 bytes read: OK
crc32 for 02000008 ... 0200000a ==> ff41d912 != 94305232 ** ERROR **
NAND read: device 0 offset 0x1c80000, size 0x40
64 bytes read: OK
NAND read: device 0 offset 0x7380000, size 0x40
64 bytes read: OK
NAND read: device 0 offset 0x7900000, size 0x40
64 bytes read: OK
reading colibri_t20/colibri_t20-512-v12-nand.img
991232 bytes read in 108 ms (8.8 MiB/s)
NAND erase: device 0 offset 0x0, size 0x300000
Erasing at 0x2c0000 -- 100% complete.
OK
NAND write: device 0 offset 0x0, size 0xf2000
991232 bytes written: OK
ubi0: default fastmap pool size: 200
ubi0: default fastmap WL pool size: 100
ubi0: attaching mtd1
ubi0: scanning is finished
ubi0: attached mtd1 (name "mtd=3", size 1020 MiB)
ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 253952 bytes
ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 4096
ubi0: VID header offset: 4096 (aligned 4096), data offset: 8192
ubi0: good PEBs: 4071, bad PEBs: 9, corrupted PEBs: 0
ubi0: user volume: 0, internal volumes: 1, max. volumes count: 128
ubi0: max/mean erase counter: 1/1, WL threshold: 4096, image sequence number: 0
ubi0: available PEBs: 3994, total reserved PEBs: 77, PEBs reserved for bad PEB handling: 71
Creating static volume kernel of size 8388608
Creating static volume dtb of size 131072
No size specified -> Using max size (1005395968)
Creating dynamic volume rootfs of size 1005395968
reading colibri_t20/zImage
4086944 bytes read in 367 ms (10.6 MiB/s)
4086944 bytes written to volume kernel
reading colibri_t20/ubifs_248KiB.img
200368128 bytes read in 16294 ms (11.7 MiB/s)
200368128 bytes written to volume rootfs
22 bytes written to volume dtb
reading colibri_t20/tegra20-colibri-eval-v3.dtb
** Unable to read file colibri_t20/tegra20-colibri-eval-v3.dtb **
size > volume size! Aborting!
resetting ...
After above method I am getting ubifs error , I have tried to erase the ubi part according to below instruction. After erasing the ubi part tried to update the image again but same ubifs error occured
Nand Erase ubi part Details
[upload|FYIZoqVo8zzLVtpYk5rArdkDyJ8=]
100 bytes read: OK
64 bytes read: OK
crc32 for 02000008 ... 0200000a ==> ffffff00 != 94305232 ** ERROR **
64 bytes read: OK
64 bytes read: OK
64 bytes read: OK
991232 bytes read in 195 ms (4.8 MiB/s)
OK
ubi0: empty MTD device detected
ubi0: max/mean erase counter: 1/0, WL threshold: 4096, image sequence number: 0
4086944 bytes read in 368 ms (10.6 MiB/s)
200368128 bytes read in 16375 ms (11.7 MiB/s)
resetting ...
UBIFS Error Details
Starting Rebuild Journal Catalog... [377/1909][ OK ] Started Flush Journal to Persistent Storage.
[ OK ] Started Load/Save Random Seed.
[ 20.301567] UBIFS error (pid 116): ubifs_read_node: bad node type (119 but expected 2)
[ 20.315036] UBIFS error (pid 116): ubifs_read_node: bad node at LEB 163:67784, LEB mapping status 1
[ 20.332906] Not a node, first 24 bytes:
[ 20.336769] 00000000: 20 0b a1 01 31 34 a1 01 54 35 ad 04 77 36 ad 04 77 2e ae 04 77 45 b0 b9
...14..T5..w6..w...wE..
[ [ 20.363532] [<c00143c8>] (unwind_backtrace+0x0/0xe8) from [<c0560b80>] (dump_stack+0x20/0x24)
OK 20.377193] [<c0560b80>] (dump_stack+0x20/0x24) from [<c01dfaec>] (ubifs_read_node+0x1e8/0x288)
m] Start[ 20.390887] [<c01dfaec>] (ubifs_read_node+0x1e8/0x288) from [<c01f9d2c>] (ubifs_tnc_read_nod
e+0x90/0x12c)
ed Rebui[ 20.409656] [<c01f9d2c>] (ubifs_tnc_read_node+0x90/0x12c) from [<c01e065c>] (tnc_read_node_n
m+0xc8/0x1c4)
ld Journ[ 20.428638] [<c01e065c>] (tnc_read_node_nm+0xc8/0x1c4) from [<c01e3eec>] (ubifs_tnc_next_ent
+0x168/0x19c)
al Catal[ 20.447947] [<c01e3eec>] (ubifs_tnc_next_ent+0x168/0x19c) from [<c01d8080>] (ubifs_readdir+0
x368/0x444)
og.
[ 20.467549] [<c01d8080>] (ubifs_readdir+0x368/0x444) from [<c00f2f30>] (vfs_readdir+0x7c/0xac)
[ 20.481203] [<c00f2f30>] (vfs_readdir+0x7c/0xac) from [<c00f3338>] (sys_getdents64+0x6c/0xc4)
[ [ 20.495970] [<c00f3338>] (sys_getdents64+0x6c/0xc4) from [<c000e000>] (ret_fast_syscall+0x0/0x30)
OK 20.510519] UBIFS error (pid 116): ubifs_readdir: cannot find next direntry, error -22
m] Started udev Kernel Device Manager.
Starting Create Volatile Files and Directories...
[ 20.666038] UBIFS error (pid 116): ubifs_read_node: bad node type (119 but expected 2)
[ 20.679079] UBIFS error (pid 116): ubifs_read_node: bad node at LEB 163:67784, LEB mapping status 1
[ 20.698209] Not a node, first 24 bytes:
[ 20.701991] 00000000: 20 0b a1 01 31 34 a1 01 54 35 ad 04 77 36 ad 04 77 2e ae 04 77 45 b0 b9
[ 20.730139] [<c00143c8>] (unwind_backtrace+0x0/0xe8) from [<c0560b80>] (dump_stack+0x20/0x24)
[ 20.743922] [<c0560b80>] (dump_stack+0x20/0x24) from [<c01dfaec>] (ubifs_read_node+0x1e8/0x288)
[ 20.757985] [<c01dfaec>] (ubifs_read_node+0x1e8/0x288) from [<c01f9d2c>] (ubifs_tnc_read_node+0x90/0
x12c)
[ 20.778117] [<c01f9d2c>] (ubifs_tnc_read_node+0x90/0x12c) from [<c01e065c>] (tnc_read_node_nm+0xc8/0
x1c4)
[ 20.798365] [<c01e065c>] (tnc_read_node_nm+0xc8/0x1c4) from [<c01e3eec>] (ubifs_tnc_next_ent+0x168/0
x19c)
[ OK 20.819726] [<c01e3eec>] (ubifs_tnc_next_ent+0x168/0x19c) from [<c01d8080>] (ubifs_readdir+0x3
68/0x444)
m] Started Create Volatile Files and Directories.
[ 20.840616] [<c01d8080>] (ubifs_readdir+0x368/0x444) from [<c00f2f30>] (vfs_readdir+0x7c/0xac)
, Starting Rebuild Journal Catalog... [377/1909][ OK ] Started Flush Journal to Persistent Storage.
e+0x90/0x12c)
m+0xc8/0x1c4)
+0x168/0x19c)
x368/0x444)
og.
x12c)
x1c4)
x19c)
68/0x444)
