Adding SWupdate layer on imx6ull
Hi everyone. I’m trying to add the SWupdate layer (https://github.com/sbabic/meta-swupdate) to an existent image based on Toradex 2.7 - Angstrom v2017.12, so as shown in this page based on the rocko branch of Yocto.
I’ve seen that there are other people here who seems to have succeeded, but I can’t get past this error:
DEBUG: Executing shell function do_compile
NOTE: make -j 12 HOSTCC=gcc  HOSTCXX=g++  V=1 ARCH=arm CROSS_COMPILE=arm-angstrom-linux-gnueabi- SKIP_STRIP=y
make -f scripts/Makefile.build obj=core
make -f scripts/Makefile.build obj=handlers
make -f scripts/Makefile.build obj=archival
make -f scripts/Makefile.build obj=corelib
make -f scripts/Makefile.build obj=ipc
make -f scripts/Makefile.build obj=mongoose
make -f scripts/Makefile.build obj=parser
make -f scripts/Makefile.build obj=suricatta
make -f scripts/Makefile.build obj=bootloader
make -f scripts/Makefile.build obj=tools
  /export/home/oedev/boxio/toradex/dev/iervasi/colibri-imx6ull/build-boxio-colibri-imx6ull/tmp-glibc/work/cortexa7t2hf-neon-angstrom-linux-gnueabi/swupdate/2017.07-r0/git/scripts/trylink "swupdate_unstripped" "arm-angstrom-linux-gnueabi-gcc  -march=armv7ve -mthumb -mfpu=neon -mfloat-abi=hard -mcpu=cortex-a7 --sysroot=/export/home/oedev/boxio/toradex/dev/iervasi/colibri-imx6ull/build-boxio-colibri-imx6ull/tmp-glibc/work/cortexa7t2hf-neon-angstrom-linux-gnueabi/swupdate/2017.07-r0/recipe-sysroot" " -Wall -Wshadow -Wwrite-strings -Wundef -Wstrict-prototypes -Wunused -Wunused-parameter -Wunused-function -Wunused-value -Wmissing-prototypes -Wmissing-declarations -Wno-format-security -Wold-style-definition  -finline-limit=0 -fno-builtin-strlen -fomit-frame-pointer -ffunction-sections -fdata-sections -fno-guess-branch-probability -funsigned-char -falign-functions=1 -falign-jumps=1 -falign-labels=1 -falign-loops=1 -static-libgcc -fno-unwind-tables -fno-asynchronous-unwind-tables -Os   -DNO_SSL_DL -DUSE_LUA -DUSE_IPV6 " "  -Wl,-E" "core/built-in.o handlers/built-in.o" "archival/lib.a corelib/lib.a ipc/lib.a mongoose/lib.a parser/lib.a suricatta/lib.a bootloader/lib.a" "pthread lua m dl config crypto ssl ubi mtd z z ubootenv "
  /export/home/oedev/boxio/toradex/dev/iervasi/colibri-imx6ull/build-boxio-colibri-imx6ull/tmp-glibc/work/cortexa7t2hf-neon-angstrom-linux-gnueabi/swupdate/2017.07-r0/git/scripts/trylink "tools/client" "arm-angstrom-linux-gnueabi-gcc  -march=armv7ve -mthumb -mfpu=neon -mfloat-abi=hard -mcpu=cortex-a7 --sysroot=/export/home/oedev/boxio/toradex/dev/iervasi/colibri-imx6ull/build-boxio-colibri-imx6ull/tmp-glibc/work/cortexa7t2hf-neon-angstrom-linux-gnueabi/swupdate/2017.07-r0/recipe-sysroot" " -Wall -Wshadow -Wwrite-strings -Wundef -Wstrict-prototypes -Wunused -Wunused-parameter -Wunused-function -Wunused-value -Wmissing-prototypes -Wmissing-declarations -Wno-format-security -Wold-style-definition  -finline-limit=0 -fno-builtin-strlen -fomit-frame-pointer -ffunction-sections -fdata-sections -fno-guess-branch-probability -funsigned-char -falign-functions=1 -falign-jumps=1 -falign-labels=1 -falign-loops=1 -static-libgcc -fno-unwind-tables -fno-asynchronous-unwind-tables -Os   -DNO_SSL_DL -DUSE_LUA -DUSE_IPV6 " "  -Wl,-E" "tools/client.o" "archival/lib.a corelib/lib.a ipc/lib.a mongoose/lib.a parser/lib.a suricatta/lib.a bootloader/lib.a" "pthread lua m dl config crypto ssl ubi mtd z z ubootenv "
  /export/home/oedev/boxio/toradex/dev/iervasi/colibri-imx6ull/build-boxio-colibri-imx6ull/tmp-glibc/work/cortexa7t2hf-neon-angstrom-linux-gnueabi/swupdate/2017.07-r0/git/scripts/trylink "tools/sendtohawkbit" "arm-angstrom-linux-gnueabi-gcc  -march=armv7ve -mthumb -mfpu=neon -mfloat-abi=hard -mcpu=cortex-a7 --sysroot=/export/home/oedev/boxio/toradex/dev/iervasi/colibri-imx6ull/build-boxio-colibri-imx6ull/tmp-glibc/work/cortexa7t2hf-neon-angstrom-linux-gnueabi/swupdate/2017.07-r0/recipe-sysroot" " -Wall -Wshadow -Wwrite-strings -Wundef -Wstrict-prototypes -Wunused -Wunused-parameter -Wunused-function -Wunused-value -Wmissing-prototypes -Wmissing-declarations -Wno-format-security -Wold-style-definition  -finline-limit=0 -fno-builtin-strlen -fomit-frame-pointer -ffunction-sections -fdata-sections -fno-guess-branch-probability -funsigned-char -falign-functions=1 -falign-jumps=1 -falign-labels=1 -falign-loops=1 -static-libgcc -fno-unwind-tables -fno-asynchronous-unwind-tables -Os   -DNO_SSL_DL -DUSE_LUA -DUSE_IPV6 " "  -Wl,-E" "tools/sendtohawkbit.o" "archival/lib.a corelib/lib.a ipc/lib.a mongoose/lib.a parser/lib.a suricatta/lib.a bootloader/lib.a" "pthread lua m dl config crypto ssl ubi mtd z z ubootenv "
  /export/home/oedev/boxio/toradex/dev/iervasi/colibri-imx6ull/build-boxio-colibri-imx6ull/tmp-glibc/work/cortexa7t2hf-neon-angstrom-linux-gnueabi/swupdate/2017.07-r0/git/scripts/trylink "tools/hawkbitcfg" "arm-angstrom-linux-gnueabi-gcc  -march=armv7ve -mthumb -mfpu=neon -mfloat-abi=hard -mcpu=cortex-a7 --sysroot=/export/home/oedev/boxio/toradex/dev/iervasi/colibri-imx6ull/build-boxio-colibri-imx6ull/tmp-glibc/work/cortexa7t2hf-neon-angstrom-linux-gnueabi/swupdate/2017.07-r0/recipe-sysroot" " -Wall -Wshadow -Wwrite-strings -Wundef -Wstrict-prototypes -Wunused -Wunused-parameter -Wunused-function -Wunused-value -Wmissing-prototypes -Wmissing-declarations -Wno-format-security -Wold-style-definition  -finline-limit=0 -fno-builtin-strlen -fomit-frame-pointer -ffunction-sections -fdata-sections -fno-guess-branch-probability -funsigned-char -falign-functions=1 -falign-jumps=1 -falign-labels=1 -falign-loops=1 -static-libgcc -fno-unwind-tables -fno-asynchronous-unwind-tables -Os   -DNO_SSL_DL -DUSE_LUA -DUSE_IPV6 " "  -Wl,-E" "tools/hawkbitcfg.o" "archival/lib.a corelib/lib.a ipc/lib.a mongoose/lib.a parser/lib.a suricatta/lib.a bootloader/lib.a" "pthread lua m dl config crypto ssl ubi mtd z z ubootenv "
  /export/home/oedev/boxio/toradex/dev/iervasi/colibri-imx6ull/build-boxio-colibri-imx6ull/tmp-glibc/work/cortexa7t2hf-neon-angstrom-linux-gnueabi/swupdate/2017.07-r0/git/scripts/trylink "tools/progress" "arm-angstrom-linux-gnueabi-gcc  -march=armv7ve -mthumb -mfpu=neon -mfloat-abi=hard -mcpu=cortex-a7 --sysroot=/export/home/oedev/boxio/toradex/dev/iervasi/colibri-imx6ull/build-boxio-colibri-imx6ull/tmp-glibc/work/cortexa7t2hf-neon-angstrom-linux-gnueabi/swupdate/2017.07-r0/recipe-sysroot" " -Wall -Wshadow -Wwrite-strings -Wundef -Wstrict-prototypes -Wunused -Wunused-parameter -Wunused-function -Wunused-value -Wmissing-prototypes -Wmissing-declarations -Wno-format-security -Wold-style-definition  -finline-limit=0 -fno-builtin-strlen -fomit-frame-pointer -ffunction-sections -fdata-sections -fno-guess-branch-probability -funsigned-char -falign-functions=1 -falign-jumps=1 -falign-labels=1 -falign-loops=1 -static-libgcc -fno-unwind-tables -fno-asynchronous-unwind-tables -Os   -DNO_SSL_DL -DUSE_LUA -DUSE_IPV6 " "  -Wl,-E" "tools/progress.o" "archival/lib.a corelib/lib.a ipc/lib.a mongoose/lib.a parser/lib.a suricatta/lib.a bootloader/lib.a" "pthread lua m dl config crypto ssl ubi mtd z z ubootenv "
Failed: -Wl,--start-group -lpthread -llua -lm -ldl -lconfig -lcrypto -lssl -lubi -lmtd -lz -lubootenv -Wl,--end-group
Output of:
arm-angstrom-linux-gnueabi-gcc -march=armv7ve -mthumb -mfpu=neon -mfloat-abi=hard -mcpu=cortex-a7 --sysroot=/export/home/oedev/boxio/toradex/dev/iervasi/colibri-imx6ull/build-boxio-colibri-imx6ull/tmp-glibc/work/cortexa7t2hf-neon-angstrom-linux-gnueabi/swupdate/2017.07-r0/recipe-sysroot -Wall -Wshadow -Wwrite-strings -Wundef -Wstrict-prototypes -Wunused -Wunused-parameter -Wunused-function -Wunused-value -Wmissing-prototypes -Wmissing-declarations -Wno-format-security -Wold-style-definition -finline-limit=0 -fno-builtin-strlen -fomit-frame-pointer -ffunction-sections -fdata-sections -fno-guess-branch-probability -funsigned-char -falign-functions=1 -falign-jumps=1 -falign-labels=1 -falign-loops=1 -static-libgcc -fno-unwind-tables -fno-asynchronous-unwind-tables -Os -DNO_SSL_DL -DUSE_LUA -DUSE_IPV6 -Wl,-E -o swupdate_unstripped -Wl,--sort-common -Wl,--gc-sections -Wl,--start-group core/built-in.o handlers/built-in.o archival/lib.a corelib/lib.a ipc/lib.a mongoose/lib.a parser/lib.a suricatta/lib.a bootloader/lib.a -Wl,--end-group -Wl,--start-group -lpthread -llua -lm -ldl -lconfig -lcrypto -lssl -lubi -lmtd -lz -lubootenv -Wl,--end-group
bootloader/lib.a(uboot.o):uboot.c:function bootloader_env_set: error: undefined reference to 'fw_env_flush'
collect2: error: ld returned 1 exit status
Makefile:375: recipe for target 'swupdate_unstripped' failed
make: *** [swupdate_unstripped] Error 1
make: *** Waiting for unfinished jobs....
  arm-angstrom-linux-gnueabi-strip -s --remove-section=.note --remove-section=.comment tools/progress_unstripped -o tools/progress; chmod a+x tools/progress
  arm-angstrom-linux-gnueabi-strip -s --remove-section=.note --remove-section=.comment tools/sendtohawkbit_unstripped -o tools/sendtohawkbit; chmod a+x tools/sendtohawkbit
  arm-angstrom-linux-gnueabi-strip -s --remove-section=.note --remove-section=.comment tools/client_unstripped -o tools/client; chmod a+x tools/client
  arm-angstrom-linux-gnueabi-strip -s --remove-section=.note --remove-section=.comment tools/hawkbitcfg_unstripped -o tools/hawkbitcfg; chmod a+x tools/hawkbitcfg
ERROR: oe_runmake failed
WARNING: /export/home/oedev/boxio/toradex/dev/iervasi/colibri-imx6ull/build-boxio-colibri-imx6ull/tmp-glibc/work/cortexa7t2hf-neon-angstrom-linux-gnueabi/swupdate/2017.07-r0/temp/run.do_compile.6951:1 exit 1 from 'exit 1'
ERROR: Function failed: do_compile (log file is located at /export/home/oedev/boxio/toradex/dev/iervasi/colibri-imx6ull/build-boxio-colibri-imx6ull/tmp-glibc/work/cortexa7t2hf-neon-angstrom-linux-gnueabi/swupdate/2017.07-r0/temp/log.do_compile.6951)
Here a similar question was asked, but I’m already using a recent version of U-Boot (or at least I think so) so I can’t explain why such an error.
I’m still not very experienced with the Yocto workflow, so it’s possible that I’m missing something important, but I can’t see it.
Matteo Iervasi
Hi @jackhack96
Thanks for writing to the Toradex Support.
bootloader/lib.a(uboot.o):uboot.c:function bootloader_env_set: error: undefined reference to ‘fw_env_flush’
Makefile:375: recipe for target ‘swupdate_unstripped’ failed
The definition of fw_env_flush is missing. Could you check if this function is defined somewhere?
Hi @jaski.tx
I’ve found the definition of fw_env_flush in build-boxio-colibri-imx6ull/tmp-glibc/work/colibri_imx6ull-angstrom-linux-gnueabi/u-boot-fw-utils/1_2017.09-r0/git/tools/env/fw_env.c at row 309:
int fw_env_flush(struct env_opts *opts)
	int ret;
	if (!opts)
		opts = &default_opts;
	if (opts->aes_flag) {
		ret = env_aes_cbc_crypt(environment.data, 1,
					opts->aes_key);
		if (ret) {
			fprintf(stderr,
				"Error: can't encrypt env for flash\n");
			return ret;
	 * Update CRC
	*environment.crc = crc32(0, (uint8_t *) environment.data, ENV_SIZE);
	/* write environment back to flash */
	if (flash_io(O_RDWR)) {
		fprintf(stderr,
			"Error: can't write fw_env to flash\n");
			return -1;
	return 0;
That’s what puzzles me, I don’t know if it’s taking the right recipe…
Best regards
Matteo
hi @jackhack96
Thanks for your input.
Bsp 2.7 is not supported any more. Could you update to Bsp 2.8.7 and also use the rocko branch from SWupdate layer?
I’m already using the rocko branch for SWupdate and BSP 2.8. I didn’t updated to the June maintenance release, but the 2.8 base is there.
Thanks for the patience
Matteo
Hi @jackhack96,
Are you still facing this issue or managed to solve it already?
André Curvello
Yes I’m still facing it but honestly I didn’t touch anything since September.
Now I’ve returned to this issue but I’m considering Mender as it seems more easy to set up (though I don’t know if we can stay on BSP 2.8)
I agree with @jaski.tx that the root cause of the issue is:
Are you sure you added the layers resources to the bblayers.conf definition in your Yocto build?
I saw a similar issue as yours here in this Google Forum for SWUpdate, and the response was “(…) the problem regarding u-boot is due to an old version of u-boot in the layer of the board provider”
Here is also a similar issue with a possible solution as well.
André Curvello
Well, I added meta-swupdate in that file.
The problem is that the U-Boot version that comes with BSP 2.8 is 2016.11, which is too old (in fact there’s no fe_env_flush definition).
Is it possible to update Toradex U-Boot without updating the whole BSP?
Thanks for the support :slight_smile:
Hi @jackhack96,
As it’s about U-Boot, there is a chance that this is possible, in theory.
You’d have to do the arrangements in Yocto so the U-Boot layer makes the reference for the same branch of our BSP 3.0.4.
You can see the branches/tables in our “Build U-Boot and Linux Kernel from Source Code” page.
But do you prefer to keep the BSP 2.8?
If it’s possible, I’d recommend you to move to the BSP 3.0.4.
André Curvello
Ok I’ve finally managed to integrate SWupdate without changing the BSP (@andrecurvello.tx I was asked to not touch the BSP layer, anyway I was told that an update is scheduled in the future, but before that our proprietary layers have to be updated accordingly and more importantly extensive testing has to be done in order to ensure stability).
All I’ve done is to take U-Boot 2019 recipes from the thud branch of meta-toradex-nxp and meta-toradex-bsp-common, and create a bbappend for libubootenv of SWupdate (just take the one in its recipes-bsp folder and rename to u-boot-toradex-fw-utils).
Thanks for all the support!
Hi @jackhack96,
Thanks for the update! Good news.
And thanks for sharing the steps you’ve made.
André Curvello
