Hi! I want to define a root password for accessing the SoM. I have added the following lines to local.conf:
EXTRA_IMAGE_FEATURES=""
INHERIT += "extrausers"
EXTRA_USERS_PARAMS = "usermod -P 1234 root;"
I confirm that local access is possible using the password defined above, but when accessing the SoM via SSH I get an access denied message (I have tried both the password above and a blank password).
This is my sshd_config file (located in oe-core\layers\openembedded-core\meta\recipes-connectivity\openssh\openssh) which I have manually edited before building the image (I have included only the uncommented options):
PermitRootLogin yes
AuthorizedKeysFile .ssh/authorized_keys
PasswordAuthentication yes
ChallengeResponseAuthentication no
Compression no
ClientAliveInterval 15
ClientAliveCountMax 4
Subsystem sftp /usr/libexec/sftp-server
Also, it is weird that I cannot find the /etc/ssh folder for checking the actual sshd_config file. If I do not set a root password as described above, then access to the SoM is possible both locally and remotely (via SSH) using a blank password.
Does anybody know how can I configure the root password to be used both locally and remotely via SSH? Are there other configurations necessary?
