Hi.
Using colibri imx6 I want to do ip forwarding. I decided to use iptables for that.
I added the package to my local.conf file
IMAGE_INSTALL:append = " nano tmux htop iptables"
After that trying to run iptables -L returned following error
root@colibri-imx6-11176894:/lib/modules# iptables -L
modprobe: FATAL: Module ip_tables not found in directory /lib/modules/6.1.55-6.4.0-devel+git.d23900f974e0
iptables v1.8.7 (legacy): can't initialize iptables table `filter': Table does not exist (do you need to insmod?)
Perhaps iptables or your kernel needs to be upgraded.
then I started for research I found following link
After the execution of this command
bitbake -c savedefconfig virtual/kernel
I created my own layer my configuration looks like this
spear@spear-Aspire-A515-47:~/batman/layers/meta-oozer/recipes-kernel/linux$ ls
files linux-toradex-ti_6.1.bbappend
spear@spear-Aspire-A515-47:~/batman/layers/meta-oozer/recipes-kernel/linux$ cat linux-toradex-ti_6.1.bbappend
SRC_URI += "file://defconfig"
KERNEL_DEFCONFIG = "${WORKDIR}/defconfig"
FILESEXTRAPATHS:prepend := "${THISDIR}/files:"
Inside ./files directory there is defconfig file I got as a result of steps that I shared in the link above. I am appending the file.
My problem is these steps couldn’t resolved my problem. I have got same error again.
What could I be missing ?
defconfig (9.5 KB)
