I have a new Apalis iMX6 D 512 V1.1A on a Ixora V1.0A
I’m trying to install a Silex SX-PCEAC using the ath10k driver. I was told by your Sanchayan Maity to :
The above article documents building kernel from source. Before building the kernel, you would have to enable the following options using make menuconfig.
CONFIG_ATH10K=y
CONFIG_ATH10K_PCI=y
Being new to this I’m hoping for a little more explicit detail. Things don’t seem to be adding up. I’m at “Kernel Configuration” in the “build-u-boot-and-linux-kernel-from-source-code” instructions. If I use menuconfig or nconfig I do not see any ath10k options. If I look in the .config file I do not see the above commands. Do I add them? nconfig shows I’m modifying “.config - Linux/arm 3.14.52 Kernel Configuration” so I think I’m in the right place.
Appreciate any help
