Are the other patches working?
Other recipes from the layer are being built OK
Could you share all the changes you have done?
Basically I made the changes needed to detect the EC20 Quectel device (following this PDF guide, part 3.2) from the sources of kernel in branch linux-toradex-4.9-2.3.x-imx as we are using the bsp 2.8b6. This is the patch content:
From 19c1aa056ae14df12bd87bc1858a4e4ec92da15c Mon Sep 17 00:00:00 2001
Date: Fri, 31 May 2019 14:52:52 +0200
Subject: [PATCH] Quectel EC20 modifications
drivers/net/usb/qmi_wwan.c | 1 -
drivers/usb/serial/option.c | 9 +++++++++
drivers/usb/serial/qcserial.c | 1 -
drivers/usb/serial/usb_wwan.c | 12 ++++++++++++
4 files changed, 21 insertions(+), 2 deletions(-)
diff --git a/drivers/net/usb/qmi_wwan.c b/drivers/net/usb/qmi_wwan.c
index 16e5c8c..2145a01 100644
--- a/drivers/net/usb/qmi_wwan.c
+++ b/drivers/net/usb/qmi_wwan.c
@@ -986,7 +986,6 @@ static const struct usb_device_id products[] = {
{QMI_GOBI_DEVICE(0x05c6, 0x9225)}, /* Sony Gobi 2000 Modem device (N0279, VU730) */
{QMI_GOBI_DEVICE(0x05c6, 0x9245)}, /* Samsung Gobi 2000 Modem device (VL176) */
{QMI_GOBI_DEVICE(0x03f0, 0x251d)}, /* HP Gobi 2000 Modem device (VP412) */
- {QMI_GOBI_DEVICE(0x05c6, 0x9215)}, /* Acer Gobi 2000 Modem device (VP413) */
{QMI_FIXED_INTF(0x05c6, 0x9215, 4)}, /* Quectel EC20 Mini PCIe */
{QMI_GOBI_DEVICE(0x05c6, 0x9265)}, /* Asus Gobi 2000 Modem device (VR305) */
{QMI_GOBI_DEVICE(0x05c6, 0x9235)}, /* Top Global Gobi 2000 Modem device (VR306) */
diff --git a/drivers/usb/serial/option.c b/drivers/usb/serial/option.c
index b2b7c12..1df25b8 100644
--- a/drivers/usb/serial/option.c
+++ b/drivers/usb/serial/option.c
@@ -238,6 +238,7 @@ static void option_instat_callback(struct urb *urb);
/* These Quectel products use Qualcomm's vendor ID */
#define QUECTEL_PRODUCT_UC20 0x9003
#define QUECTEL_PRODUCT_UC15 0x9090
+#define QUECTEL_PRODUCT_EC20 0x9215
/* These u-blox products use Qualcomm's vendor ID */
#define UBLOX_PRODUCT_R410M 0x90b2
/* These Yuga products use Qualcomm's vendor ID */
@@ -1069,6 +1070,7 @@ static const struct usb_device_id option_ids[] = {
{ USB_DEVICE(QUALCOMM_VENDOR_ID, 0x9000)}, /* SIMCom SIM5218 */
/* Quectel products using Qualcomm vendor ID */
{ USB_DEVICE(QUALCOMM_VENDOR_ID, QUECTEL_PRODUCT_UC15)},
+ { USB_DEVICE(QUALCOMM_VENDOR_ID, QUECTEL_PRODUCT_EC20)},
{ USB_DEVICE(QUALCOMM_VENDOR_ID, QUECTEL_PRODUCT_UC20),
.driver_info = RSVD(4) },
/* Yuga products use Qualcomm vendor ID */
@@ -1996,6 +1998,7 @@ static struct usb_serial_driver option_1port_device = {
#ifdef CONFIG_PM
.suspend = usb_wwan_suspend,
.resume = usb_wwan_resume,
+ .reset_resume = usb_wwan_resume,
#endif
@@ -2033,6 +2036,12 @@ static int option_probe(struct usb_serial *serial,
iface_desc->bInterfaceClass != USB_CLASS_CDC_DATA)
return -ENODEV;
+ //Quectel EC20's interface 4 can be used as USB network device
+ if (serial->dev->descriptor.idVendor == cpu_to_le16(0x05C6) &&
+ serial->dev->descriptor.idProduct == cpu_to_le16(0x9215) &&
+ serial->interface->cur_altsetting->desc.bInterfaceNumber >= 4)
+ return -ENODEV;
/* Store the device flags so we can use them during attach. */
usb_set_serial_data(serial, (void *)device_flags);
diff --git a/drivers/usb/serial/qcserial.c b/drivers/usb/serial/qcserial.c
index fb6dc16..245ed65 100644
--- a/drivers/usb/serial/qcserial.c
+++ b/drivers/usb/serial/qcserial.c
@@ -92,7 +92,6 @@ static const struct usb_device_id id_table[] = {
{USB_DEVICE(0x03f0, 0x241d)}, /* HP Gobi 2000 QDL device (VP412) */
{USB_DEVICE(0x03f0, 0x251d)}, /* HP Gobi 2000 Modem device (VP412) */
{USB_DEVICE(0x05c6, 0x9214)}, /* Acer Gobi 2000 QDL device (VP413) */
- {USB_DEVICE(0x05c6, 0x9215)}, /* Acer Gobi 2000 Modem device (VP413) */
{USB_DEVICE(0x05c6, 0x9264)}, /* Asus Gobi 2000 QDL device (VR305) */
{USB_DEVICE(0x05c6, 0x9265)}, /* Asus Gobi 2000 Modem device (VR305) */
{USB_DEVICE(0x05c6, 0x9234)}, /* Top Global Gobi 2000 QDL device (VR306) */
diff --git a/drivers/usb/serial/usb_wwan.c b/drivers/usb/serial/usb_wwan.c
index 3dfdfc8..a918f30 100644
--- a/drivers/usb/serial/usb_wwan.c
+++ b/drivers/usb/serial/usb_wwan.c
@@ -505,6 +505,18 @@ static struct urb *usb_wwan_setup_urb(struct usb_serial_port *port,
usb_sndbulkpipe(serial->dev, endpoint) | dir,
buf, len, callback, ctx);
+ if (dir == USB_DIR_OUT) {
+ struct usb_device_descriptor *desc = &serial->dev->descriptor;
+ if (desc->idVendor == cpu_to_le16(0x05C6) && desc->idProduct == cpu_to_le16(0x9090))
+ urb->transfer_flags |= URB_ZERO_PACKET;
+ if (desc->idVendor == cpu_to_le16(0x05C6) && desc->idProduct == cpu_to_le16(0x9003))
+ if (desc->idVendor == cpu_to_le16(0x05C6) && desc->idProduct == cpu_to_le16(0x9215))
+ if (desc->idVendor == cpu_to_le16(0x2C7C))
return urb;
2.7.4
What exactly do you want to do? Why do you want to change angstrom-lxde-image.bb?
Basically what I want is to use the EC20 module from Quectel I have to use it as a GNSS module, in order to do that I found this repo containing the recipe to add the EC25 module to a yocto based project, and made a similar patch but based on the EC20, the rest is all the same.
I added a modified recipe to a layer I made that contains other recipes from other projects like gpsd.
I don’t care which toradex image I use at the moment, it was just an example to test the build. In a project I found, which had many useful recipes, they modify console-tdx-image.bb and add their recipes after the IMAGE_INSTALL += " \ … and I thought that I should add my patch there with them.
Is this the right way to do it?
