Which is the right version of weston-touch-calibrator caontainer to be used with image torizon-core-docker-verdin-imx8mm-Tezi_6.1.0-devel-20230117+build.150.tar ?
Should I use :2 or :3?
Am I right that it should match the weston-vivante release (that is :2 in the torizoncore image I use)?
How can I deploy weston-touch-calibrator container to my Verdin iM8M-Mini?
Should I edit docker-compose.yml and rebuild with torizoncore-builder?
Or is there a quick way?
I’m not sure I understand. If you run docker run as documented in the linked article it will automatically pull the correct container image if it does not already exist on the system.
Hi @jeremias.tx
the Verdin is on an embedded system that doesn’t have access to internet.
It would be much easier with network access, but I can’t.
Only my devdelopment PC has access to internet.
There are two ways to run the docker container in this case that I can suggest to you (assuming that you have a USB-A port accessible on your carrier board):
Load the containers from a USB drive directly. You can save the docker image into a tar archive from your development machine using the command docker save (docker image save | Docker Docs) and then load it on the module using docker load command (docker image load | Docker Docs). You need to create separate tar files for each of your images, load them separately and then create the docker-compose file in /var/sota/storage/docker-compose directory. The module doesn’t need network access to run the containers once the images are already available locally on the module. As @jeremias.tx mentioned, you need network access only to pull the images if they don’t already exist on the system.
Use TorizonCore Builder tool to bundle your docker-compose file into the OS and then deploy it directly to the module either via SSH or by copying the Tezi image to a USB storage (Detailed Manual | Toradex Developer Center), or serving the images using a local zeroconf server.
Please let me know if you need any further asistance after you give these a try
Hello @rudhi.tx
thanks.
Next week I’ll test.
I know how to use TorizonCore Builder tool to bundle the docker-compose file, so probably I’ll go in this way.
Only one question: does weston-touch-calibrator container depends on other containers? I suppose it depends on weston-vivante only.
Something like this?
