Am trying to rebuild the SDK using do_populate_sdk. I keep getting massive, massive errors when bitbake executes do_compile for nativesdk-opencv. As in, generates a log file of 12000+ lines of errors. Here’s an example:
test_lshtable_badarg.cpp:(.text._ZN11opencv_test12_GLOBAL__N_121CV_LshTableBadArgTestD2Ev+0xb): undefined reference to `cvtest::BadArgTest::~BadArgTest()'
They all appear to be “undefined reference” errors.
This looks to me they are all related, and most likely a fundamental assignment, package addition, or other yocto setting is in order, but I am flummoxed as to what that might be. Here’s what I have so far:
I’ve created a bbappend file for opencv recipe and added “nativesdk” to BBCLASSEXTEND. I have not added nativesdk-opencv to TOOLCHAIN_HOST_TASK because the dependency for nativesdk-opencv was generated by gstreamer1.0-plugins-base, which I do have included in TOOLCHAIN_HOST_TASK.
The production image builds fine: everything compiles, including opencv, without errors, but when building sdk, opencv gives me fits.
Any pointers in the right direction?
