add libgpio to project
Hi
beginner question: I followed this tutorial Visual Studio Code IDE Extension | Toradex Developer Center but I can’t get my simple application to link. This is the output I’m getting:
> Executing task: arm-linux-gnueabihf-g++ -g TestGPIO.cpp -o TestGPIO <
/usr/lib/gcc-cross/arm-linux-gnueabihf/10/../../../../arm-linux-gnueabihf/bin/ld: /tmp/cccCNdZL.o: in function `main':
/workspaces/TestGPIO/TestGPIO.cpp:15: undefined reference to `gpiod_ctxless_set_value'
collect2: error: ld returned 1 exit status
The terminal process "bash '-c', 'arm-linux-gnueabihf-g++ -g TestGPIO.cpp -o TestGPIO'" terminated with exit code: 1.
It must be something small, but as a beginner, I have no clue where to start. Any help is much appreciated!
Managed to get it running by adding “-l” and “gpiod” to “args” in tasks.json. I guess using a makefile would have been easier.
Glad you were able to get it going.
But yes if you’re not using a makefile based project then the compile/gcc commands are defined in tasks.json. Meaning that’s where you would have to add the link to any libraries.
