hi experts
i asked a related question before and got some help and saw tens of times
and thought i can add fec2 but i failed
when i changed dts file ( see below) , fec1 ,fec2 could n’t get connect phy
here is log
[ OK ] Started Permit User Sessions.
[ OK ] Started Getty on tty1.
[ OK ] Started Serial Getty on ttymxc0.
[ 8.308979] Generic PHY 30bf0000.ethernet-1:01: attached PHY driver [Generic PHY] (mii_bus:phy_addr=30bf0000.ethernet-1:01, irq=POLL)
[ OK ] Reached target Login Prompts.
**8.328535] fec 30be0000.ethernet eth1: Unable to connect to phy
[ OK ] Started Avahi mDNS/DNS-SD Stack.
[ OK ] Reached target Multi-User System.
and i wonder fec1 in devicetree was registered as eth0 where could i change the loading order of fec1 and fec2
the chage i made in devicetree
&fec2 {
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_enet2>;
clocks = <&clks IMX7D_ENET2_IPG_ROOT_CLK>,
<&clks IMX7D_ENET_AXI_ROOT_CLK>,
<&clks IMX7D_ENET2_TIME_ROOT_CLK>,
<&clks IMX7D_PLL_ENET_MAIN_50M_CLK>;
clock-names = "ipg", "ahb", "ptp", "enet_clk_ref";
assigned-clocks = <&clks IMX7D_ENET2_TIME_ROOT_SRC>,
<&clks IMX7D_ENET2_TIME_ROOT_CLK> ;
assigned-clock-parents = <&clks IMX7D_PLL_ENET_MAIN_100M_CLK>;
assigned-clock-rates = <0>, <100000000>;
local-mac-address = [00 15 6c 10 20 30];
phy-mode = "rmii";
fsl.magic-packet;
phy-handle = < ðphy1>;
status = "disabled";
mdio {
#address-cells = <1>;
#size-cells = <0>;
ethphy1: ethernet-phy@1 {
compatible = "ethernet-phy-ieee802.3-c22";
max-speed = <100>;
micrel,led-mode = <0>;
reg = <1>;
&fec2 {
&fec1 {
&iomux {
pinctrl_enet2: enet2grp {
fsl,pins = <
MX7D_PAD_EPDC_SDCE0__ENET2_RGMII_RX_CTL 0x73
MX7D_PAD_EPDC_SDCLK__ENET2_RGMII_RD0 0x73
MX7D_PAD_EPDC_SDLE__ENET2_RGMII_RD1 0x73
MX7D_PAD_EPDC_SDCE1__ENET2_RX_ER 0x73
MX7D_PAD_EPDC_GDRL__ENET2_RGMII_TX_CTL 0x73
MX7D_PAD_EPDC_SDCE2__ENET2_RGMII_TD0 0x73
MX7D_PAD_EPDC_SDCE3__ENET2_RGMII_TD1 0x73
MX7D_PAD_EPDC_BDR0__CCM_ENET_REF_CLK2 0x73
MX7D_PAD_GPIO1_IO14__ENET2_MDIO 0x3
MX7D_PAD_GPIO1_IO15__ENET2_MDC 0x3
thank you in advance
