Hi support,
I have a problem with dts overlay custom include in my torizon core builder project.
This is my dts overlay custom file:
* Copyright 2023 Toradex
// Verdin iMX8M Plus single-channel LVDS
/dts-v1/;
/plugin/;
compatible = "toradex,verdin-imx8mp"; // Set hardware compatibility
backlight_lvds_native: backlight-lvds-native {
compatible = "pwm-backlight";
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_i2s_2_d_out_dsi_1_bkl_en>;
brightness-levels = <0 45 63 88 119 158 203 255>;
default-brightness-level = <4>;
/* Verdin I2S_2_D_OUT as GPIO (SODIMM 46) */
enable-gpios = <&gpio5 1 GPIO_ACTIVE_HIGH>;
/* Verdin PWM_2 (SODIMM 16) */
pwms = <&pwm2 0 6666667 PWM_POLARITY_INVERTED>;
panel-lvds-native {
compatible = "panel-lvds";
backlight = <&backlight_lvds_native>;
data-mapping = "vesa-24";
height-mm = <136>; /* Height active area */
width-mm = <217>; /* Width active area */
panel-timing {
clock-frequency = <72400000>;
de-active = <1>;
hactive = <1280>;
hback-porch = <86>;
hfront-porch = <72>;
hsync-active = <0>;
hsync-len = <2>;
pixelclk-active = <1>;
vactive = <800>;
vback-porch = <21>;
vfront-porch = <15>;
vsync-active = <0>;
vsync-len = <2>;
port {
panel_lvds_native_in: endpoint {
remote-endpoint = <&lvds_out>;
&gpu_2d {
&gpu_3d {
/* Verdin I2C channel 1 */
&i2c2 {
ilitek@41 {
compatible = "ilitek,ili251x";
reg = <0x41>;
interrupt-parent = <&gpio4>;
interrupts = <31 IRQ_TYPE_EDGE_FALLING>;
reset-gpios = <&gpio4 30 GPIO_ACTIVE_LOW>;
pinctrl-0 = <&pinctrl_i2s_2_d_in_gpio>,
<&pinctrl_i2s_2_sync_gpio>;
&lcdif2 {
&ldb {
lvds-channel@0 {
#address-cells = <1>;
#size-cells = <0>;
reg = <0>;
fsl,data-mapping = "spwg";
fsl,data-width = <24>;
port@1 {
reg = <1>;
#size-cells = <0>;
lvds_out: endpoint {
remote-endpoint = <&panel_lvds_native_in>;
&ldb_phy {
&mix_gpu_ml {
&ml_vipsi {
/* Verdin PWM_2 */
&pwm2 {
&iomuxc {
/* Reset pin */
pinctrl_i2s_2_d_in_gpio: gpio4io30grp {
fsl,pins =
<MX8MP_IOMUXC_SAI3_RXD__GPIO4_IO30 0x184>; /* SODIMM 48 */
/* Interrupt pin */
pinctrl_i2s_2_sync_gpio: gpio4io31grp {
fsl,pins =
<MX8MP_IOMUXC_SAI3_TXFS__GPIO4_IO31 0x1c4>; /* SODIMM 44 */
pinctrl_i2s_2_d_out_dsi_1_bkl_en: i2s2doutdsi1bklengrp {
fsl,pins =
<MX8MP_IOMUXC_SAI3_TXD__GPIO5_IO01 0x184>; /* SODIMM 46 */
and this is my tcb-build.yml file:
input:
easy-installer:
remote: https://tezi.toradex.com/artifactory/torizoncore-oe-prod-frankfurt/scarthgap-7.x.y/release/30/verdin-imx8mp/torizon/torizon-docker/oedeploy/torizon-docker-verdin-imx8mp-Tezi_7.5.0+build.30.tar
customization:
device-tree:
include-dirs:
- device-trees/overlays
custom: linux-toradex/arch/arm64/boot/dts/freescale/imx8mp-verdin-wifi-mallow.dts
overlays:
add:
- device-trees/overlays/verdin-imx8mp_panel-touch-10inch-lvds_overlay.dts
output:
easy-installer:
local: torizon-image
accept-licence: true
autoinstall: true
bundle:
compose-file: containers/docker-compose.yml
when i run torizoncore-builder build command return this error:
Building image as per configuration file 'tcbuild.yaml'...
=>> Handling input section
Fetching URL 'https://tezi.toradex.com/artifactory/torizoncore-oe-prod-frankfurt/scarthgap-7.x.y/release/30/verdin-imx8mp/torizon/torizon-docker/oedeploy/torizon-docker-verdin-imx8mp-Tezi_7.5.0+build.30.tar' into '/tmp/torizon-docker-verdin-imx8mp-Tezi_7.5.0+build.30.tar'
Download Complete!
Downloaded file name: '/tmp/torizon-docker-verdin-imx8mp-Tezi_7.5.0+build.30.tar'
No integrity check performed because checksum was not specified.
Unpacking Toradex Easy Installer image.
Unpacking TorizonCore Toradex Easy Installer image.
Importing OSTree revision b48dbccb33ac49e6a61d82a6ae7953ddc00e624569caaabc1033b4cf6adfd793 from local repository...
1286 metadata, 9890 content objects imported; 652.2 MB content written
0 metadata, 0 content objects imported; 0 bytes content written
Unpacked OSTree from Toradex Easy Installer image:
Commit checksum: b48dbccb33ac49e6a61d82a6ae7953ddc00e624569caaabc1033b4cf6adfd793
TorizonCore Version: 7.5.0+build.30
=>> Handling customization section
=> Handling device-tree subsection
Not testing overlay because base image does not have a device-tree set!
=> Adding device-tree overlay 'device-trees/overlays/verdin-imx8mp_panel-touch-10inch-lvds_overlay.dts'
Compiling Device Tree with DTC 1.6.0...
Error: device-trees/overlays/verdin-imx8mp_panel-touch-10inch-lvds_overlay.dts:25.28-29 syntax error
FATAL ERROR: Unable to parse input tree
error: cannot apply device-trees/overlays/verdin-imx8mp_panel-touch-10inch-lvds_overlay.dts.
The row 25 is the follow:
How can i resolve this issue? And exists an method for include custom: linux-toradex/arch/arm64/boot/dts/freescale/imx8mp-verdin-wifi-mallow.dts without clone linux-toradex repository?
Fabio
