Add a new package to meta-toolchain-qte
Hi!
I’ve tried to add the package “curl” to the meta-toolchain-qte without success.
I added the command IMAGE_INSTALL_append = " curl" to conf/local.conf but it didn’t work. I tried to add the same command to meta meta-toolchain-qte.bb as well, without success.
The bitbake doesn’t generate the toolchain with curl support. Furthermore, I generated the pn-buildlist file and the file didn’t show the curl package.
What am I doing wrong?
Ives.
Hi Ives
Maybe you could add it to RDEPENDS_${PN} in ./openembedded-core/meta/recipes-qt/packagegroups/packagegroup-qt-toolchain-target.inc. (or add RDEPENDS_packagegroup-qte-toolchain-target_append = " curl" to local.conf)
However the better way would be to build the SDK for your image. i.e.
'bitbake <image_name> -c populate_sdk'.
Assuming that your image deploys curl, the resulting SDK will contain the developer packages of curl and all other packages deployed with the image.
Max
Hi Max.
Good idea about ‘bitbake -c populate_sdk’. Now the SDK contains the “curl” headers but seems that it didn’t build the qt sdk to cross compile to the target. I couldn’t find the qmake2 command on the installed dir (“/usr/local/oecore-x86_64”). I executed ‘bitbake meta-toolchain-qte -c populate_sdk’.
The “*host.manifest” file didn’t show the following packages.
nativesdk-packagegroup-qte-toolchain-host x86_64-nativesdk 1.0-r12
nativesdk-qt4-tools x86_64-nativesdk 4.8.7-r0
Do you have any idea why the qmake2 command is not in the SDK?
Thanks for all.
Hi Max!
I did the other solution you said. I created a new layer on stuff folder named “meta-mycompany” with recipes to add the package curl. Now it’s working…
But I still don’t know why the command qmake2 is not in the SDK after the execution of the command “bitbake meta-toolchain-qte -c populate_sdk”
Ives.
