I’m running the ADC example provided in: git://git.toradex.com/freertos-toradex.git.
everything seem to work correctly except the output value of ADC.
The value does not correspond to the external source voltage connected to ADC0 input ( x14: 1 on colibri board) at all.
The value changes gradually sometimes when I change the input voltage on ADC0 eventhough I disabled the average output feature in the channel initialization struct:
adc_logic_ch_init_config_t adcChannelConfig = {
.inputChannel = BOARD_ADC_INPUT_CHANNEL,
.coutinuousEnable = true,
.convertRate = 5,
.averageEnable = false
When I connect the ADC0 to the GND of the board, the value changes gradually and stabilize on 0.80 v (instead of 0.0 v). The raw output value of “ADC_GetConvertResult” is also the same behaviour.
I can’t find out what is the problem. (btw: Cortex-A on u-boot)
Majd
