I’m having problems integrating a AD7606-8 device.
It works fine when I control it using python and setting the gpios directly.
But when I try to activate the driver and use the iio-device I get a timeout when trying to read voltage data under /sys/bus/iio/devices/iio:device0 with cat in_voltage0_raw for example.
Here is the relevant part of my devicetree:
&ecspi1 {
status = "ok";
cs-gpios = <&gpio3 26 GPIO_ACTIVE_LOW>;
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_ecspi1 &pinctrl_ecspi1_cs>;
adc4: adc@0 {
compatible = "adi,ad7606-8";
pinctrl-0 = <&pinctrl_adc_colibri>;
reg = <0>;
spi-max-frequency = <1000000>;
avcc-supply = <&adc_vref>;
spi-cpol;
//spi-cpha;
num-channels = <8>;
// SODIMM 133
interrupts = <14 IRQ_TYPE_EDGE_FALLING>;
interrupt-parent = <&gpio4>;
// SODIMM 135
adi,conversion-start-gpios = <&gpio1 24 GPIO_ACTIVE_HIGH>;
// SODIMM 98
reset-gpios = <&gpio4 26 GPIO_ACTIVE_HIGH>;
// SODIMM 85
adi,first-data-gpios = <&gpio4 27 GPIO_ACTIVE_HIGH>;
// SODIMM 103, 101, 97 ?
// SODIMM 79 ?
//standby-gpios = <&gpio4 23 GPIO_ACTIVE_LOW>;
adi,sw-mode;
spidev0: spidev@0 {
status = "disabled";
pinctrl_ecspi1_cs: ecspi1-cs-grp {
fsl,pins = <
MX6UL_PAD_LCD_DATA21__GPIO3_IO26 0x70a0 /* SODIMM 86 */
pinctrl_ecspi1: ecspi1-grp {
fsl,pins = <
MX6UL_PAD_LCD_DATA20__ECSPI1_SCLK 0x000a0 /* SODIMM 88 */
MX6UL_PAD_LCD_DATA23__ECSPI1_MISO 0x100a0 /* SODIMM 90 */
MX6UL_PAD_LCD_DATA22__ECSPI1_MOSI 0x000a0 /* SODIMM 92 */
pinctrl_adc_colibri: adc_colibri-grp {
fsl,pins = <
MX6UL_PAD_NAND_CE1_B__GPIO4_IO14 0x10b0 /* SODIMM 133 xxx */
MX6UL_PAD_UART3_TX_DATA__GPIO1_IO24 0x10b0 /* SODIMM 135 xxx */
MX6UL_PAD_CSI_DATA05__GPIO4_IO26 0x10b0 /* SODIMM 98 xxx */
MX6UL_PAD_CSI_DATA06__GPIO4_IO27 0x10b0 /* SODIMM 85 xxx */
MX6UL_PAD_CSI_DATA03__GPIO4_IO24 0x10b0 /* SODIMM 97 xxx */
MX6UL_PAD_CSI_DATA00__GPIO4_IO21 0x10b0 /* SODIMM 101 xxx */
MX6UL_PAD_CSI_DATA01__GPIO4_IO22 0x10b0 /* SODIMM 103 xxx */
MX6UL_PAD_CSI_DATA02__GPIO4_IO23 0x10b0 /* SODIMM 79 xxx */
Any ideas what could be wrong here?
