root@apalis-tk1:~/wifi_pkg/laird_3_5_5_43# iw dev
phy#0
Interface wlan0
ifindex 9
wdev 0x1
addr c0:ee:40:40:18:fa
type managed
txpower 0.00 dBm
root@apalis-tk1:~/wifi_pkg/laird_3_5_5_43# iw dev mlan0 del
command failed: No such device (-19)
root@apalis-tk1:~/wifi_pkg/laird_3_5_5_43# iw dev wlan0 del
root@apalis-tk1:~/wifi_pkg/laird_3_5_5_43# iw phy phy0 interface add wlan0 type ibss
command failed: Operation not supported (-95)
root@apalis-tk1:~/wifi_pkg/laird_3_5_5_43# dmesg | tail -n100
[ 260.056771] EXT4-fs (mmcblk0p2): resizing filesystem from 3833600 to 3834880 blocks
[ 260.072673] EXT4-fs (mmcblk0p2): resized filesystem to 3834880
[ 512.982186] igb 0000:01:00.0 enp1s0: igb: enp1s0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX/TX
[ 513.005596] IPv6: ADDRCONF(NETDEV_CHANGE): enp1s0: link becomes ready
[ 765.494020] mmc2: card b368 removed
[ 771.669214] sdhci-tegra sdhci-tegra.2: Found T2T coeffs data
[ 771.685784] sdhci-tegra sdhci-tegra.2: 200MHz tap hole coeffs found
[ 772.331640] Auto tuning windows***
[ 772.337621] WIN_ATTR legend: 0-BOUN_ST, 1-BOUN_END, 2-HOLE
[ 772.344066] win[0]: 0(0) - 41(1)
[ 772.347917] win[1]: 60(0) - 129(1)
[ 772.351849] win[2]: 148(0) - 217(1)
[ 772.355941] win[3]: 236(0) - 255(1)
[ 772.359943] ***************************************
[ 772.365667] ***tuning windows after inserting holes
[ 772.371658] WIN_ATTR legend: 0-BOUN_ST, 1-BOUN_END, 2-HOLE
[ 772.377315] win[0]:-28(0) - 8(2)
[ 772.380695] win[1]:10(2) - 41(1)
[ 772.384165] win[2]:60(0) - 96(2)
[ 772.387675] win[3]:98(2) - 129(1)
[ 772.391172] win[4]:148(0) - 184(2)
[ 772.394732] win[5]:186(2) - 217(1)
[ 772.398281] win[6]:236(0) - 255(1)
[ 772.401899] ***********************************************
[ 772.407736] *Tuning values
[ 772.412172] estimated values
[ 772.415556] T2T_Vmax 58, T2T_Vmin 81, 1’st_hole_Vmax 8, UI_Vmax 86
[ 772.421984] Calculated values
[ 772.425487] T2T_Vmax 56, 1’st_hole_Vmax 9, UI_Vmax 88
[ 772.430732] T2T_Vmin 56, 1’st_hole_Vmin 9, UI_Vmin 89
[ 772.436028] ***********************************
[ 772.441551] *final tuning windows
[ 772.446994] win[0]: -11 - 1
[ 772.449923] win[1]: 18 - 24
[ 772.453023] win[2]: 77 - 84
[ 772.455956] win[3]: 112 - 112
[ 772.459088] win[4]: 165 - 166
[ 772.462177] win[5]: 206 - 200
[ 772.465259] win[6]: 253 - 238
[ 772.468341] ********************************
[ 772.472762] best tap win - (77-84), best tap value 80 prev_best_tap 0
[ 772.479396] sdhci-tegra sdhci-tegra.2: Found T2T coeffs data
[ 772.485673] sdhci-tegra sdhci-tegra.2: 200MHz tap hole coeffs found
[ 773.131408] Auto tuning windows***
[ 773.137192] WIN_ATTR legend: 0-BOUN_ST, 1-BOUN_END, 2-HOLE
[ 773.142797] win[0]: 0(0) - 40(1)
[ 773.147538] win[1]: 61(0) - 128(1)
[ 773.151583] win[2]: 148(0) - 217(1)
[ 773.155196] win[3]: 236(0) - 255(1)
[ 773.158773] ***************************************
[ 773.163742] ***tuning windows after inserting holes
[ 773.169510] WIN_ATTR legend: 0-BOUN_ST, 1-BOUN_END, 2-HOLE
[ 773.175015] win[0]:-27(0) - 8(2)
[ 773.178259] win[1]:10(2) - 40(1)
[ 773.181492] win[2]:61(0) - 96(2)
[ 773.184733] win[3]:98(2) - 128(1)
[ 773.188064] win[4]:148(0) - 184(2)
[ 773.191498] win[5]:186(2) - 217(1)
[ 773.195006] win[6]:236(0) - 255(1)
[ 773.198498] ***********************************************
[ 773.204158] *Tuning values
[ 773.208527] estimated values
[ 773.211846] T2T_Vmax 58, T2T_Vmin 81, 1’st_hole_Vmax 8, UI_Vmax 86
[ 773.218093] Calculated values
[ 773.221422] T2T_Vmax 56, 1’st_hole_Vmax 9, UI_Vmax 88
[ 773.226472] T2T_Vmin 56, 1’st_hole_Vmin 9, UI_Vmin 89
[ 773.231520] ***********************************
[ 773.236052] *final tuning windows
[ 773.241141] win[0]: -10 - 1
[ 773.243967] win[1]: 18 - 23
[ 773.246770] win[2]: 78 - 84
[ 773.249568] win[3]: 112 - 111
[ 773.252535] win[4]: 165 - 166
[ 773.255503] win[5]: 206 - 200
[ 773.258469] win[6]: 253 - 238
[ 773.261445] ********************************
[ 773.265719] best tap win - (78-84), best tap value 81 prev_best_tap 80
[ 773.272248] sdhci-tegra sdhci-tegra.2: sdhci_tegra_verify_best_tap: tuning freq 200000000hz, best tap 81
[ 773.285262] mmc2: new ultra high speed SDR104 SDIO card at address 0001
[ 792.050538] Loading modules backported from Linux version LRD-REL-3.5.5.43-0-g90c1682
[ 792.063706] Backport generated by backports.git LRD-REL-3.5.5.43-0-g8771847
[ 812.653591] <>
[ 812.667148] SDIO Vendor ID:02df and SDIO Device ID: 9141
[ 812.675863] ieee80211 phy0: lrdmwl_sdio: SDIO FUNC1 IO port: 0x10000
[ 812.683199] ieee80211 phy0: mwl_sdio_init_irq, register IRQ
[ 812.697411] ieee80211 phy0: lrdmwl: found firmware image
[ 812.710389] ieee80211 phy0: downloading FW image (345928 bytes)
[ 813.349766] ieee80211 phy0: FW download over, size 345928 bytes
[ 813.356230] ieee80211 phy0: Checking fw status 100
[ 814.271708] ieee80211 phy0: Waiting on fw status 10 0x0
[ 814.691614] ieee80211 phy0: firmware is ready 14
[ 814.707780] ieee80211 phy0: =>mwl_sdio_enable_int(): enable host interrupt ok
[ 815.730408] ieee80211 phy0: firmware version: 0x8050214
[ 815.760191] ieee80211 phy0: Setting strict regulatory
[ 815.760403] ieee80211 phy0: firmware region code: ff
[ 815.768367] ieee80211 phy0: OTP data len = 0
[ 815.773263] ieee80211 phy0: Command Rejected by FW
[ 815.778530] ieee80211 phy0: mwl_set_caps: Antcfg = 00000003(2) 00000003(2)
[ 815.821165] ieee80211 phy0: 2G enabled, 5G enabled
[ 815.847798] ieee80211 phy0: 2 TX antennas, 2 RX antennas
