Due to a design error, my motherboard give an inverted signal (compared to Colibri eval board) for the SD card detect signal. In a first time, I inverted the active signal in my dts file and the issue was repaired when Linux is running. But I discovered that it is not the case in U-Boot when I want to update the Colibri iMX6 from SDCard (SD card not detected) because dtb file is not loaded.
Does it is possible that U-Boot read the SD Card without taking into account the signal SD card detect (as broken_cd do it in dts file)?
