I am testing ADV7180 on ACM v1.1 on Apalis i.MX6 with Linux V2.5beta3(Linux kernel comes from toradex_imx_3.14.28_1.0.0_ga-next brach). After installing modules, there is an error.
root@apalis-imx6:~/modules/capture# insmod ipu_still.ko
root@apalis-imx6:~/modules/capture# insmod ipu_fg_overlay_sdc.ko
root@apalis-imx6:~/modules/capture# insmod ipu_prp_enc.ko
root@apalis-imx6:~/modules/capture# insmod v4l2-int-device.ko
root@apalis-imx6:~/modules/capture# insmod adv7180_tvin.ko
[ 37.893354] adv7180 3-0021: no sensor pwdn pin available
root@apalis-imx6:~/modules/capture# insmod mxc_v4l2_capture.ko
[ 47.614675] mxc_v4l2_master_attach: ipu0:/csi0 parallel attached adv7180:mxc_v4l2_cap0
root@apalis-imx6:~/modules/capture# [ 47.637083] ERROR: v4l2 capture: slave not found! V4L2_CID_HUE
[ 47.645155] ERROR: v4l2 capture: slave not found! V4L2_CID_HUE
The video standard of ADV7180 is not correct.
root@apalis-imx6:~/modules/capture# v4l2-ctl --device /dev/video0 --all
Driver Info (not using libv4l2):[ 183.325059] ERROR: unrecognized std! ffffff (PAL=ff, NTSC=b000
Driver name : mxc_v4l2
Card type :
Bus info :
Driver version: 0.1.11
Capabilities : 0x05000005
Video Capture
Video Overlay
Read/Write
Streaming
Video input : 0 (CSI IC MEM: ok)
Video output: 0 (DISP3 BG)
Video Standard = 0x00ffffff
PAL-B/B1/G/H/I/D/D1/K/M/N/Nc/60
NTSC-M/M-JP/443/M-KR
SECAM-B/D/G/H/K/K1/L/Lc
Format Video Capture:
So there is only blue windows when streaming the video from camera. Resistor R64 on ACM is assembled.
root@apalis-imx6:~/modules/capture# gst-launch tvsrc ! imxv4l2sink disp_width=720 disp_height=576
MFW_GST_tvsrc_PLUGIN 3.0.7 build on Jul 31 2013 18:18:05.
[ 199.682486] ERROR: v4l2 capture: slave not found! V4L2_CID_HUE
[ 199.688402] ERROR: v4l2 capture: slave not found! V4L2_CID_HUE
MFW_GST_V4LSINK_PLUGIN 4.0.3 build on Dec 15 2015 16:00:19[ 199.703890] ERROR: unrecognized std! ffffff (PAL=ff, NTSC=b000
Setting pipeline to PAUSED ...
sensor chip is adv7180_decoder
should set the input to 1
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
full screen size:1920x1080
[V4L Update Display]: left=0, top=0, width=720, height=576
set v4l display crop sucessfully
set v4l rotate sucessfully
>>V4L_SINK: Actually buffer status:
hardware buffer : 12
software buffer : 0
