Dear Jeremias,
I manage to install drivers and libraries for different USB camera (from NIT New Imaging Technology in France, and IDS Imaging) on Torizon.
I am able to access the camera as root user (user: 0:0 in docker-compose.yml) but not as user torizon.
I would like to access it as non-root user (mainly because I would like to display on weston, and that does not work as root, and xhost in not available on the target).
The docker-compose.yml I use is the following (so here without the user: 0:0 option) :
# docker-compose.yml
services:
nit-interface_arm64v8-qt5-vivante-no-ssh_bullseye_debug_513050ae-f541-4a8a-baef-1599a9e43911:
cap_add:
- ALL
depends_on:
- weston
device_cgroup_rules:
- c 4:0 rmw
- c 4:7 rmw
- c 13:* rmw
- c 189:* rmw
- c 81:* rmw
- c 245:* rmw
- c 199:* rmw
- c 226:* rmw
devices:
- /dev/bus/usb/002/002
- /dev/bus/usb/002/001
- /dev/bus/usb/001/001
- /dev/bus/usb/003/003
- /dev/bus/usb/003/002
- /dev/bus/usb/003/001
image: nit-interface_arm64v8-qt5-vivante-no-ssh_bullseye_debug_513050ae-f541-4a8a-baef-1599a9e43911
network_mode: host
ports:
- 6502/tcp
privileged: 'true'
volumes:
- /tmp:/tmp:rw
- /dev/dri:/dev/dri:rw
- /dev/galcore:/dev/galcore:rw
- /dev:/dev:rw
- /dev/bus:/dev/bus:rw
- /run:/run:rw
- /home/torizon/nit-interface:/nit-interface:rw
weston:
cap_add:
- CAP_SYS_TTY_CONFIG
- c 4:0 rmw
- c 4:7 rmw
- c 13:* rmw
- c 199:* rmw
- c 226:* rmw
environment:
- ACCEPT_FSL_EULA=1
image: torizon/weston-vivante:2
network_mode: host
volumes:
- source: /tmp
target: /tmp
type: bind
- source: /dev
target: /dev
type: bind
- source: /run/udev
target: /run/udev
type: bind
version: '2.4'
I gathered various info that might be useful for debugging (here with NIT camera) :
The camera uses Cypress drivers and the following udev rule was added on the target container
## cat /etc/udev/rules.d/88-cyusb.rules
KERNEL=="*", SUBSYSTEM=="usb", ENV{DEVTYPE}=="usb_device", ATTR{idVendor}=="04b4", MODE="0666", GROUP="plugdev", TAG="cyusb_dev"
The camera on the target container shows as follows with lsusb:
## lsusb -v -s 002:002
Bus 002 Device 002: ID 04b4:00f1 Cypress Semiconductor Corp. USB3
Couldn't open device, some information will be missing
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 3.00
bDeviceClass 0
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 9
idVendor 0x04b4 Cypress Semiconductor Corp.
idProduct 0x00f1
bcdDevice 0.00
iManufacturer 1 New Imaging Technologies
iProduct 2 USB3
iSerial 3 v002.000.001
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 0x001f
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 0
bmAttributes 0x80
(Bus Powered)
MaxPower 400mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 255 Vendor Specific Class
bInterfaceSubClass 0
bInterfaceProtocol 0
iInterface 0
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x83 EP 3 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0400 1x 1024 bytes
bInterval 0
bMaxBurst 15
When ran as root, (-u:0:0), lsub show a bit more information :
Binary Object Store Descriptor:
bLength 5
bDescriptorType 15
wTotalLength 0x0016
bNumDeviceCaps 2
USB 2.0 Extension Device Capability:
bLength 7
bDescriptorType 16
bDevCapabilityType 2
bmAttributes 0x00000002
HIRD Link Power Management (LPM) Supported
SuperSpeed USB Device Capability:
bLength 10
bDescriptorType 16
bDevCapabilityType 3
bmAttributes 0x00
wSpeedsSupported 0x000e
Device can operate at Full Speed (12Mbps)
Device can operate at High Speed (480Mbps)
Device can operate at SuperSpeed (5Gbps)
bFunctionalitySupport 3
Lowest fully-functional device speed is SuperSpeed (5Gbps)
bU1DevExitLat 0 micro seconds
bU2DevExitLat 0 micro seconds
can't get debug descriptor: Resource temporarily unavailable
Device Status: 0x0000
(Bus Powered)
I also added the plugdev to the torizon user on the target container
## groups
torizon dialout audio video plugdev gpio i2cdev spidev pwm input kvm render
When I launch my application with strace on the target container, I got the error that it cannot open /dev/bus/usb/002/... ;
## strace ./nit-cam-imx8-bullseye
openat(AT_FDCWD, "/sys/bus/usb/devices/usb2/busnum", O_RDONLY|O_CLOEXEC) = 5
read(5, "2\n", 20) = 2
close(5) = 0
openat(AT_FDCWD, "/sys/bus/usb/devices/usb2/devnum", O_RDONLY|O_CLOEXEC) = 5
read(5, "1\n", 20) = 2
close(5) = 0
openat(AT_FDCWD, "/sys/bus/usb/devices/usb2/speed", O_RDONLY|O_CLOEXEC) = 5
read(5, "5000\n", 20) = 5
close(5) = 0
openat(AT_FDCWD, "/sys/bus/usb/devices/usb2/descriptors", O_RDONLY|O_CLOEXEC) = 5
read(5, "\22\1\0\3\t\0\3\tk\35\3\0\4\5\3\2\1\1\t\2\37\0\1\1\0\340\0\t\4\0\0\1"..., 256) = 49
close(5) = 0
openat(AT_FDCWD, "/", O_RDONLY|O_CLOEXEC|O_PATH|O_DIRECTORY) = 5
openat(5, "sys", O_RDONLY|O_NOFOLLOW|O_CLOEXEC|O_PATH) = 6
fstat(6, {st_mode=S_IFDIR|0555, st_size=0, ...}) = 0
close(5) = 0
openat(6, "devices", O_RDONLY|O_NOFOLLOW|O_CLOEXEC|O_PATH) = 5
fstat(5, {st_mode=S_IFDIR|0755, st_size=0, ...}) = 0
close(6) = 0
openat(5, "platform", O_RDONLY|O_NOFOLLOW|O_CLOEXEC|O_PATH) = 6
fstat(6, {st_mode=S_IFDIR|0755, st_size=0, ...}) = 0
close(5) = 0
openat(6, "bus@5b000000", O_RDONLY|O_NOFOLLOW|O_CLOEXEC|O_PATH) = 5
close(6) = 0
openat(5, "5b110000.usb3", O_RDONLY|O_NOFOLLOW|O_CLOEXEC|O_PATH) = 6
close(5) = 0
openat(6, "xhci-cdns3", O_RDONLY|O_NOFOLLOW|O_CLOEXEC|O_PATH) = 5
close(6) = 0
openat(5, "usb2", O_RDONLY|O_NOFOLLOW|O_CLOEXEC|O_PATH) = 6
close(5) = 0
openat(6, "2-1", O_RDONLY|O_NOFOLLOW|O_CLOEXEC|O_PATH) = 5
close(6) = 0
close(5) = 0
faccessat(AT_FDCWD, "/sys/devices/platform/bus@5b000000/5b110000.usb3/xhci-cdns3/usb2/2-1/uevent", F_OK) = 0
openat(AT_FDCWD, "/sys/devices/platform/bus@5b000000/5b110000.usb3/xhci-cdns3/usb2/2-1/uevent", O_RDONLY|O_CLOEXEC) = 5
fstat(5, {st_mode=S_IFREG|0644, st_size=4096, ...}) = 0
read(5, "MAJOR=189\nMINOR=129\nDEVNAME=bus/"..., 4096) = 124
read(5, "", 4096) = 0
close(5) = 0
getrandom(0xffffb39b6938, 16, GRND_NONBLOCK|GRND_INSECURE) = -1 EINVAL (Invalid argument)
getrandom("\x9e\xc1\x80\x6f\x53\x5a\xee\x21\x37\x0c\x4e\x80\xf2\xd5\xd7\x3a", 16, GRND_NONBLOCK) = 16
getrandom("\x6a\x5c\xe1\xd7\x59\x6d\x4c\xa1\x10\x0a\x5a\xa4\xbf\x85\x3f\x53", 16, GRND_NONBLOCK) = 16
openat(AT_FDCWD, "/sys/bus/usb/devices/2-1/busnum", O_RDONLY|O_CLOEXEC) = 5
close(5) = 0
openat(AT_FDCWD, "/sys/bus/usb/devices/2-1/devnum", O_RDONLY|O_CLOEXEC) = 5
close(5) = 0
openat(AT_FDCWD, "/sys/bus/usb/devices/2-1/speed", O_RDONLY|O_CLOEXEC) = 5
close(5) = 0
openat(AT_FDCWD, "/sys/bus/usb/devices/2-1/descriptors", O_RDONLY|O_CLOEXEC) = 5
read(5, "\22\1\0\3\0\0\0\t\264\4\361\0\0\0\1\2\3\1\t\2\37\0\1\1\0\2002\t\4\0\0\1"..., 256) = 49
close(5) = 0
eventfd2(0, EFD_CLOEXEC|EFD_NONBLOCK) = 5
write(5, "\1\0\0\0\0\0\0\0", 8) = 8
timerfd_create(CLOCK_MONOTONIC, TFD_CLOEXEC|TFD_NONBLOCK) = 6
recvmsg(3, {msg_namelen=128}, 0) = -1 EAGAIN (Resource temporarily unavailable)
openat(AT_FDCWD, "/dev/bus/usb/002/002", O_RDWR|O_CLOEXEC) = -1 EACCES (Permission denied)
openat(AT_FDCWD, "/dev/bus/usb/002/001", O_RDWR|O_CLOEXEC) = -1 EACCES (Permission denied)
openat(AT_FDCWD, "/dev/bus/usb/001/001", O_RDWR|O_CLOEXEC) = -1 EACCES (Permission denied)
openat(AT_FDCWD, "/dev/bus/usb/003/003", O_RDWR|O_CLOEXEC) = -1 EACCES (Permission denied)
openat(AT_FDCWD, "/dev/bus/usb/003/002", O_RDWR|O_CLOEXEC) = -1 EACCES (Permission denied)
openat(AT_FDCWD, "/dev/bus/usb/003/001", O_RDWR|O_CLOEXEC) = -1 EACCES (Permission denied)
write(1, "No NIT camera was discovered\n", 29No NIT camera was discovered
So this is a permission issue but I am puzzled because I tried many possibilities. To summarize :
- adding various options to
docker-compose.ymlcap_add: - ALLdevice_cgroup_rules:- c 189:* rmw- etc …devices: - /dev/bus/usb/002/002- etc…volumes: /dev/, /run, /tmpprivileged : 'true'volumes: - /dev:/dev rw - etc ...
- adding
plugdevgroup totorizon
As I mentioned, it works fine as root user, but if I run as root, then I cannot display anything on weston any more.
Any idea to solve this issue ?
Fabian
