Hello Ashley,
Welcome to the world of Docker on Torizon! You’re already on the right track by using the COPY command with the --chown flag. If your goal is for the application running as the torizon user to have write access to /home/torizon/data, the ownership and permissions on that directory and its contents are crucial.
Here’s what to check and try:
1. Ensure Ownership
Your COPY command should ensure the files and the folder are owned by the torizon user:
COPY --chown=torizon:torizon aarch64/files/ /home/torizon/data
Note it’s : not . between user and group.
2. Create the Directory as torizon
If /home/torizon/data does not exist before the COPY, Docker will create it as root. To prevent this and ensure ownership, you can create the folder first and set ownership explicitly:
RUN mkdir -p /home/torizon/data && chown torizon:torizon /home/torizon/data
COPY --chown=torizon:torizon aarch64/files/ /home/torizon/data/
3. Ensure Permissions
To allow writing:
RUN chmod 755 /home/torizon/data
If group write is needed:
RUN chmod 775 /home/torizon/data
Full Example
Here’s a concise example:
Now the torizon user should have the needed permissions to read and write in /home/torizon/data.
For more on this topic:
If something is still unclear or doesn’t work as expected, feel free to share more details!
