I have discovered that there is delay between CS falling edge to first SPI clock, and SPI last clock to CS rising edge. I want those delays to go. Similar questions have been already asked, but I could not find any solution.
I have tested SPI comunication with this code:
int spi_fd, i;
uint32_t mode;
uint8_t bits;
uint32_t speed;
char buff_tx[BUFF_SIZE];
char buff_rx[BUFF_SIZE];
struct spi_ioc_transfer buff;
speed = 1000000;
bits = 16;
mode = 0;
spi_fd = open("/dev/spidev0.0", O_RDWR | O_NONBLOCK);
memset(buff_tx, 0x65, BUFF_SIZE);
if(spi_fd < 0)
return -1;
ioctl(spi_fd, SPI_IOC_WR_MODE32, &mode);
ioctl(spi_fd, SPI_IOC_RD_MODE32, &mode);
ioctl(spi_fd, SPI_IOC_WR_BITS_PER_WORD, &bits);
ioctl(spi_fd, SPI_IOC_RD_BITS_PER_WORD, &bits);
ioctl(spi_fd, SPI_IOC_WR_MAX_SPEED_HZ, &speed);
ioctl(spi_fd, SPI_IOC_RD_MAX_SPEED_HZ, &speed);
ioctl(spi_fd, SPI_IOC_MESSAGE(1), &buff);
close(spi_fd);
return 0;
With spi_ioc_transfer I can change data speed, SPI mode, bits per word. But what about other SPI parameters?
How do I change for example Sample Period Control Register (ECSPIx_PERIODREG) on the i.Mx6ull processor? Is there a struct that can access this register?
Taras
