800x600 LVDS Display Support in Win CE8 on Colibri iMX6
I have an NEC NL8060BC21-11F LVDS LCD display that has 800x600 resolution. I noticed the WinCE8 Platform Builder catalog view only supports 640x480, 800x480 and 1920x1080p resolution. What is the easiest way to drive this 800x600 LVDS display on the Colibri module under Windows CE8?
Did you try to set registry values for your display as described here - https://developer.toradex.com/knowledge-base/display-driver-registry-settings?
I actually hadn’t come across that page. Thanks for the reference. Is there any way to make these changes directly to the build image? I’d prefer not to have to adjust the registry settings on every device that is manufactured. It would be nice to add this registry setting directly to the Platform Builder built image.
Nevermind, I found the setting in the Platform Builder workspace. I’ll add it there.
