I am using a 7" capacitive display with the Colibri IMx6 and Aster Carrier Board. Until recently, everything worked correctly. However, now a fraction of the screen isn’t displaying, with a permanent black bar with colored stripes, and the resolution of the remainder of the screen seems degraded. I took a picture:
Meanwhile. while configuring another module for testing, I got the following error:
U-Boot 2016.11-1.7.0+gf4db39ecb6 (Jul 31 2018 - 11:24:02 +0000)
CPU: Freescale i.MX6DL rev1.4 at 792 MHz
Reset cause: POR
I2C: ready
DRAM: 512 MiB
PMIC: device id: 0x10, revision id: 0x21, programmed
MMC: FSL_SDHC: 0, FSL_SDHC: 1
Using default environment
In: serial_mxc
Out: serial_mxc
Err: serial_mxc
Model: Toradex Colibri iMX6 DualLite 512MB V1.1A, Serial# 10770311
Net: using PHY at 0
FEC [PRIME]
MMC: no card present
switch to partitions #0, OK
Scanning mmc 0:1...
Found U-Boot script /boot.scr
reading /boot.scr
524 bytes read in 11 ms (45.9 KiB/s)
## Executing script at 17000000
reading /tezi.itb
20807396 bytes read in 584 ms (34 MiB/s)
## Loading kernel from FIT Image at 12200000 ...
Using 'config@1' configuration
Trying 'kernel@1' kernel subimage
Description: Linux Kernel 4.1
Type: Kernel Image
Compression: uncompressed
Data Start: 0x122000dc
Data Size: 5097296 Bytes = 4.9 MiB
Architecture: ARM
OS: Linux
Load Address: 0x11000000
Entry Point: 0x11000000
Hash algo: md5
Hash value: 6b0443dad3a0fbe3e5c49198b76782e4
Verifying Hash Integrity ... md5+ OK
## Loading ramdisk from FIT Image at 12200000 ...
Trying 'ramdisk@1' ramdisk subimage
Description: SquashFS RAMdisk
Type: RAMDisk Image
Data Start: 0x126dc914
Data Size: 15663104 Bytes = 14.9 MiB
Architecture: ARM
OS: Linux
Load Address: unavailable
Entry Point: unavailable
Hash algo: md5
Hash value: 6faf2df2c2eb5ef23680728b1f26b094
## Loading fdt from FIT Image at 12200000 ...
Trying 'fdt@1' fdt subimage
Description: Colibri iMX6 Device Tree
Type: Flat Device Tree
Data Start: 0x135cc9e0
Data Size: 45520 Bytes = 44.5 KiB
Architecture: ARM
Hash algo: md5
Hash value: cd0cc8dcbf9082218ffc4498613cc416
Booting using the fdt blob at 0x135cc9e0
Loading Kernel Image ... OK
Loading Device Tree to 1fff1000, end 1ffff1cf ... OK
Starting kernel ...
[ 0.425390] imx_usb 2184000.usb: Can't register ci_hdrc platform device, err=-517
[ 0.762431] snvs-secvio 20cc000.caam-snvs: can't get snvs clock
Running /etc/rc.local...
Colibri-iMX6_ToradexEasyInstaller_1.7-20180731
Welcome to Toradex Easy Installer
This is a Linux based installer for Toradex modules. Currently the
installer does not have a serial console interface. You can use the
Toradex Easy Installer through any of the available display interfaces
using USB mouse/keyboard or via network using VNC. Use:
# ip addr show eth0
to display the Ethernet IP address or use USB RNDIS at IP 192.168.11.1.
/ # [ 152.450586] Alignment trap: not handling instruction e1932f9f at [<7633b69c>]
[ 152.457843] Unhandled fault: alignment exception (0x001) at 0x00000065
[ 152.464411] pgd = 82270000
[ 152.467123] [00000065] *pgd=122ec831, *pte=00000000, *ppte=00000000
Since you are using Torizon, this is the article you should look into, can you please try to enable the overlay for the Capacitive Touch Display 7" Parallel?
Since the VGA is working, the problem is probably related to the video configuration, please try the overlay as mentioned above and share with us the results.
I believe I had succesfully applied the overlays. I get the following output:
~/dev/tcbworkdir$ torizoncore-builder dto status
Enabled overlays over device tree imx6dl-colibri-eval-v3.dtb:
- colibri-imx6_atmel-mxt-connector_overlay.dtbo
- display-lt161010_overlay.dtbo
Which are the required overlays according to guide. Indeed, after applying these changes, it seems the situation got worse: the screen locks displaying white with colored lines.
Was the problem solved by restoring the uboot environment?
For additional information, you also need to apply the overlay colibri-imx6_parallel-rgb_overlay.dtb to enable the RGB along side the other two overlays.
The Toradex-supplied u-boot can’t detect which of their LCDs is installed, which leads to this problem. Maybe they will take this under advisement in future systems.
