I’m trying to play a 4K content on my Apalis IMX8 on Ixora board (V1.2A).
For prototyping purpose, I’ve installed the Full Multimedia Reference image.
I tried the following pipeline:
root@apalis-imx8:~# gst-launch-1.0 -v filesrc location=/media/sda1/4k_content.mkv ! qtdemux name=d d.video_0 ! queue ! h265parse ! v4l2h265dec ! imxvideoconvert_g2d ! queue ! waylandsink
But it failed:
error: XDG_RUNTIME_DIR not set in the environment. 0:00:00.188971226 1069 0xaaaac60c9e00 WARN waylandsink gstwaylandsink.c:428:gst_wayland_sink_find_display:<waylandsink0> warning: Could not initialise Wayland output 0:00:00.189001100 1069 0xaaaac60c9e00 WARN waylandsink gstwaylandsink.c:428:gst_wayland_sink_find_display:<waylandsink0> warning: Failed to create GstWlDisplay: 'Failed to connect to the wayland display '(default)'' ERROR: Pipeline doesn't want to pause. WARNING: from element /GstPipeline:pipeline0/GstWaylandSink:waylandsink0: Could not initialise Wayland output Additional debug info: ../git/ext/wayland/gstwaylandsink.c(428): gst_wayland_sink_find_display (): /GstPipeline:pipeline0/GstWaylandSink:waylandsink0: Failed to create GstWlDisplay: 'Failed to connect to the wayland display '(default)'' Setting pipeline to NULL ...
I guess there’s a issue with Wayland. Is there something I need to check in the reference multimedia linux system ?
I also tried to use glimagesink but it ended with SIGSEGV.
gst-launch-1.0 -v filesrc location=/media/sda1/4k_content.mkv ! qtdemux name=d d.video_0 ! queue ! h265parse ! v4l2h265dec ! queue ! glimagesink async=false enable-last-sample=false qos=false sync=false
Setting pipeline to PAUSED ...
Caught SIGSEGV
exec gdb failed: No such file or directory
Spinning. Please run 'gdb gst-launch-1.0 1173' to continue debugging, Ctrl-C to quit, or Ctrl-\ to dump core
I’m just wondering if there’s something with the pipeline above or if I need to check further the linux wayland configuration ?
Thanks.
Karim
