Looking for suggestions as to the right way to fix this problem.
Build info:
My build machine is running Ubuntu 15.10 amd64
I am using the recommended kernel and the following environment for cross compiling:
export CC=/opt/linaro/gcc-linaro-4.9-2014.11-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-
export CROSS_COMPILE=${CC}
export ARCH=arm
export PATH=/opt/linaro/gcc-linaro-4.9-2014.11-x86_64_arm-linux-gnueabihf/bin/:$PATH
I cloned the kernel tree and did git checkout toradex_imx_3.14.52_1.1.0_ga
Configured the kernel and built with:
make -j4 LOCALVERSION=-${BUILD} LOADADDR=10008000 uImage
Which gave the following error:
drivers/mmc/host/sdhci-pltfm.c: In function 'sdhci_pltfm_suspend':
drivers/mmc/host/sdhci-pltfm.c:246:2: error: implicit declaration of function 'pinctrl_pm_select_sleep_state' [-Werror=implicit-function-declaration]
pinctrl_pm_select_sleep_state(dev);
drivers/mmc/host/sdhci-pltfm.c: In function 'sdhci_pltfm_resume':
drivers/mmc/host/sdhci-pltfm.c:256:2: error: implicit declaration of function 'pinctrl_pm_select_default_state' [-Werror=implicit-function-declaration]
pinctrl_pm_select_default_state(dev);
cc1: some warnings being treated as errors
scripts/Makefile.build:308: recipe for target 'drivers/mmc/host/sdhci-pltfm.o' failed
make[3]: *** [drivers/mmc/host/sdhci-pltfm.o] Error 1
scripts/Makefile.build:455: recipe for target 'drivers/mmc/host' failed
make[2]: *** [drivers/mmc/host] Error 2
scripts/Makefile.build:455: recipe for target 'drivers/mmc' failed
make[1]: *** [drivers/mmc] Error 2
Makefile:845: recipe for target 'drivers' failed
make: *** [drivers] Error 2
make: *** Waiting for unfinished jobs....
CC lib/raid6/int2.o
Found a reference on the web for errors with implicit declarations of pinctrl_pm_select_sleep_state
From the log I guess wee need the include file:
> "#include "
I tried this which compiled that file and got the same error on another file.
In any case mostly I am wondering if anyone else has seen this?
Also wondering if adding the header is the right thing to do or if this is an indication of a problem with my build system that is showing up in this manner? In which case I need to get an idea of what I do need to fix.
Any suggestions would be greatly appreciated.
Curtis
More info:
After adding that header the next complaint is:
drivers/usb/chipidea/ci_hdrc_imx.c: In function 'ci_hdrc_imx_notify_event':
drivers/usb/chipidea/ci_hdrc_imx.c:264:4: error: implicit declaration of function 'pinctrl_select_state' [-Werror=implicit-function-declaration]
ret = pinctrl_select_state(data->pinctrl,
data->pinctrl = devm_pinctrl_get(&pdev->dev);
drivers/usb/chipidea/ci_hdrc_imx.c:408:16: warning: assignment makes pointer from integer without a cast
drivers/us
And after adding the header there I get:
LD init/built-in.o
drivers/built-in.o: In function ci_hdrc_host_resume:
:(.text+0x8d9bc): undefined reference to imx_gpc_mf_request_on
drivers/built-in.o: In function ci_hdrc_host_suspend:
:(.text+0x8dfe4): undefined reference to imx_gpc_mf_request_on
sound/built-in.o: In function snd_dmaengine_pcm_close:
:(.text+0x14cc0): undefined reference to dma_sync_wait_tasklet
Makefile:831: recipe for target 'vmlinux' failed
