new problem with this setup → iMX8m-mini + Dahlia + 10" DSI Riverdi display (standard flex cable)
We have a sporadic interference on the screen, and could not yet find when it happens - seems to be on Coldstart but not 100% sure. The problem can be seen on the video attached and has been replicated on 3 different setups (as described above)
tdx-info:
interference display.zip (619.4 KB)
Software summary
Bootloader: U-Boot
Kernel version: 5.15.129-6.5.0+git.6f8fd49366db #1-TorizonCore SMP PREEMPT Fri Dec 22 11:15:52 UTC 2023
Kernel command line: root=LABEL=otaroot rootfstype=ext4 quiet logo.nologo vt.global_cursor_default=0 plymouth.ignore-serial-consoles splash fbcon=map:3 ostree=/ostree/boot.1/torizon/f66094621623afbf2f90fe298498edbedf8d8b115a61d3e2017c2d62b975a207/0
Distro name: NAME="TorizonCore"
Distro version: VERSION_ID=6.5.0-build.8
Distro variant: VARIANT="Docker"
Hostname: verdin-imx8mm-14756390
Hardware info
HW model: Toradex Verdin iMX8M Mini WB on Verdin Development Board
Toradex version: 0060 V1.1C
Serial number: 14756390
Processor arch: aarch64
