10.1 inch Capacitive Touch and Display Not Working
I cannot operate the Capacitive touch module. Can you share the correct configuration settings with us? What are the steps we need to take?
I arranged the Device tree for multi touch as follows.
atmel_mxt_ts: atmel_mxt_ts@4a {
compatible = "atmel,maxtouch";
reg = <0x4a>;
interrupt-parent = <&gpio6>;
interrupts = <10 IRQ_TYPE_EDGE_FALLING>;
- status = "disabled";
+ status = "okay";
In order for the display to work properly, I have arranged the Device tree as follows.
lvds-channel@0 {
reg = <0>;
fsl,data-mapping = "spwg"; /* "jeida"; */
- fsl,data-width = <18>;
+ fsl,data-width = <24>;
crtc = "ipu2-di1";
primary;
The screen and multi-touch do not work. What adjustments should I make to the B2Qt image?
HI @yusufsatilmis and Welcome to the Toradex Community!
Could you provide the exact software version of your module ( uname -a )?
Please share the dmesg.log in a text file?
Thanks and best regards,
That should really be super easy. Let me show you…
compatible = “atmel,maxtouch”;
reg = <0x4a>;
  •           status = "disabled";
  •           status = "okay";
Yes, just replacing disabled with okay should do the trick. However, I am not sure what exact device tree you took as a base as yours is missing the reset pin part. Plus better would be to explicitly do the pin muxing. Find attached patch. The base I used is the following:
http://git.toradex.com/cgit/linux-toradex.git/log/?h=toradex_4.9-2.3.x-imx
lvds-channel@0 {
reg = <0>;
fsl,data-mapping = “spwg”; /* “jeida”; */
crtc = “ipu2-di1”;
primary;
status = “okay”;
Yes, also this is sufficient. However, we recommend setting the native-mode directly in the device tree while you’re anyway at it.
The screen is working properly now. But the touch doesn’t work. The error I wrote below
occurs for the i2c port.
dmesg > dmesg.txt
[ 6.453464] atmel_mxt_ts 0-004a: __mxt_read_reg: i2c transfer failed (-6)
[ 6.475050] atmel_mxt_ts 0-004a: mxt_bootloader_read: i2c recv failed (-6)
[ 6.487348] atmel_mxt_ts 0-004a: Trying alternate bootloader address
[ 6.499996] atmel_mxt_ts 0-004a: mxt_bootloader_read: i2c recv failed (-6)
[    6.210986] atmel_mxt_ts 1-004a: Falling back to user helper
[    6.723798] atmel_mxt_ts 1-004a: Touchscreen size X1279Y799
[    6.745972] input: Atmel maXTouch Touchscreen as /devices/soc0/soc/2100000.aips-bus/21a0000.i2c/i2c-1/1-004a/input/input2
[    6.774404] atmel_mxt_ts 1-004a: Family: 164 Variant: 11 Firmware V1.2.AA Objects: 41
BTW: That is what I set in U-Boot:
setenv fdt_file imx6q-apalis-ixora-v1.2.dtb
setenv vidargs 'mxc_hdmi.only_cea=1 video=mxcfb0:dev=ldb,if=RGB24 video=mxcfb1:off video=mxcfb2:off video=mxcfb3:off fbmem=32M'
saveenv
And don’t forget to actually deploy the imx6q-apalis-ixora-v1.2.dtb to /media/mmcblk0p1 on the target.
root@b2qt-apalis-imx6:~# uname -a
Linux b2qt-apalis-imx6 4.14.117-0+ge43e3a26e1b7 #1 SMP Fri Dec 13 13:05:10 UTC 2019 armv7l armv7l armv7l GNU/Linux
link text
dmesg no touch
dmesg touch
Currently on b2qt image the screen works.
But when I plug in the touch cord, no image appears on the screen. The screen is waiting Black.
When I remove the touch cord, the screen works properly.
I added the dmesg files. What would be the reason?
HI @yusufsatilmis
Could you share some pictures showing how you connect display and touch interfaces on both sides?
How did you solve the issue? I have the same issue, as soon as I connect the touch cord and the atmel_mxt_ts recognizes the touchscreen, the screen gets black. When the cord is removed and atmel_mxt_ts fails recognizing the touch, the screen works fine.
