tmp/work/aarch64-poky-linux/glibc/2.27-r0/build-aarch64-poky-linux/elf/ld.so -Wl,--no-as-needed -Wl,--end-group
/media/sistlajr/2tb_hd/imx/build/tmp/work/aarch64-poky-linux/glibc/2.27-r0/build-aarch64-poky-linux/nptl/libpthread_nonshared.a(pthread_atfork.oS): In function `__pthread_atfork':
/usr/src/debug/glibc/2.27-r0/git/nptl/pthread_atfork.c:51: undefined reference to `__dso_handle'
/media/sistlajr/2tb_hd/imx/build/tmp/work/aarch64-poky-linux/glibc/2.27-r0/recipe-sysroot-native/usr/bin/aarch64-poky-linux.gcc-cross-initial-aarch64/../../libexec/aarch64-poky-linux.gcc-cross-initial-aarch64/gcc/aarch64-poky-linux/7.3.0/ld: /media/sistlajr/2tb_hd/imx/build/tmp/work/aarch64-poky-linux/glibc/2.27-r0/build-aarch64-poky-linux/rt/librt.so: hidden symbol `__dso_handle' isn't defined
/media/sistlajr/2tb_hd/imx/build/tmp/work/aarch64-poky-linux/glibc/2.27-r0/recipe-sysroot-native/usr/bin/aarch64-poky-linux.gcc-cross-initial-aarch64/../../libexec/aarch64-poky-linux.gcc-cross-initial-aarch64/gcc/aarch64-poky-linux/7.3.0/ld: final link failed: Bad value
collect2: error: ld returned 1 exit status
../Makerules:599: recipe for target '/media/sistlajr/2tb_hd/imx/build/tmp/work/aarch64-poky-linux/glibc/2.27-r0/build-aarch64-poky-linux/rt/librt.so' failed
make[2]: *** [/media/sistlajr/2tb_hd/imx/build/tmp/work/aarch64-poky-linux/glibc/2.27-r0/build-aarch64-poky-linux/rt/librt.so] Error 1
make[2]: Leaving directory '/media/sistlajr/2tb_hd/imx/build/tmp/work/aarch64-poky-linux/glibc/2.27-r0/git/rt'
Makefile:235: recipe for target 'rt/others' failed
make[1]: *** [rt/others] Error 2
make[1]: Leaving directory '/media/sistlajr/2tb_hd/imx/build/tmp/work/aarch64-poky-linux/glibc/2.27-r0/git'
Makefile:9: recipe for target 'all' failed
make: *** [all] Error 2
ERROR: oe_runmake failed
WARNING: exit code 1 from a shell command.
ERROR: Function failed: do_compile (log file is located at /media/sistlajr/2tb_hd/imx/build/tmp/work/aarch64-poky-linux/glibc/2.27-r0/temp/log.do_compile.29560)
Hello @sistlajr and Welcome to the Toradex Community!
Concerning your Issue, could you provide the following details:
- What commands did you entered to launch the compilation?
- Did you install the prerequisites?
- Could you provide the details about your host (hardware and linux distribution )?
Thanks and best regards
