Hi @ToradexAI,
here the kernel args of init=/init\0 in the appendargs for the recipes-kernel is used for?
Hi @ToradexAI,
Thanks for the conversation! I've reached my limit of replies in this thread.
If you still have questions, feel free to start a new one. I'm happy to help!
Hi @Hariprabhu_13!
You can disable kernel logs by modifying the kernel configuration option called CONFIG_LOGLEVEL_DEFAULT.
For this, I recommend reading the Yocto documentation, specifically subsections 2.6.1 to 2.6.3 of the Linux Kernel Development Manual.
Besides that, I noticed you opened another thread with the same issue. We’ll continue providing support in this one.
Best regards.
Hi @lucas_az.tx,
Based on the toradex ai given info for the kernel splash screen setup as logo at the kernel console logs space at startup, reboot, shutdown time the blank screen is displayed. after removed the logo.nologo in tdxargs at the kernel recipes.
where I need to find the solution for the splash logo at start in the kernel splash screen space, after that my device application once the weston service is up at graphical target starts.
now only the issue is the splash screen setup as logo at start, restart, reboot, shutdown time the blank space need to be fix with the logo. There is any solution for that, and need the guidance to setup the logo at kernel space.
hari@Administrator:~/oe-core/layers/meta-lokbest/recipes-graphics/splash-screen$ tree .
├── files
└── splash-screen_1.0.bb
1 directory, 2 files
hari@Administrator:~/oe-core/layers/meta-lokbest/recipes-graphics/splash-screen$ cat splash-screen_1.0.bb
SUMMARY = "Custom splash screen for kernel framebuffer"
LICENSE = "MIT"
LIC_FILES_CHKSUM = "file://${COMMON_LICENSE_DIR}/MIT;md5=0835ade698e0bcf8506ecda2f7b4f302"
SRC_URI = "file://splash-logo.bmp"
S = "${WORKDIR}"
do_install() {
install -d ${D}/usr/share/pixmaps
install -m 0644 ${WORKDIR}/splash-logo.bmp ${D}/usr/share/pixmaps/splash-logo.bmp
FILES:${PN} = "/usr/share/pixmaps/splash-logo.bmp"
hari@Administrator:~/oe-core/layers/meta-lokbest/recipes-graphics/splash-screen$ file files/splash-logo.bmp
files/splash-logo.bmp: PC bitmap, Windows 3.x format, 887 x 267 x 8, image size 237096, resolution 2835 x 2835 px/m, 256 important colors, cbSize 238174, bits offset 1078
hari@Administrator:~/oe-core/layers/meta-lokbest/recipes-kernel$ tree .
└── linux
├── files
│ ├── ppp.cfg
│ └── verdin-imx8mp-qmi.cfg
├── linux-toradex
│ └── fast-boot.cfg
└── linux-toradex_%.bbappend
3 directories, 4 files
hari@Administrator:~/oe-core/layers/meta-lokbest/recipes-kernel$ cat linux/linux-toradex_%.bbappend
FILESEXTRAPATHS:prepend := "${THISDIR}/linux-toradex:"
FILESEXTRAPATHS:prepend := "${THISDIR}/files:"
unset KBUILD_DEFCONFIG
SRC_URI += "\
file://fast-boot.cfg \
file://verdin-imx8mp-qmi.cfg \
file://ppp.cfg \
KERNEL_CONFIG_FRAGMENTS += "fast-boot.cfg verdin-imx8mp-qmi.cfg ppp.cfg"
# REMOVE logo.nologo to allow logo display
APPENDARGS += " quiet loglevel=0 vt.global_cursor_default=0 vt.default_redraw=0 console=tty0 init=/init"
RDEPENDS:${KERNEL_PACKAGE_NAME}-base += "splash-screen"
hari@Administrator:~/oe-core/layers/meta-lokbest/recipes-kernel$ cat linux/linux-toradex/fast-boot.cfg
# Enable framebuffer console for splash
CONFIG_FRAMEBUFFER_CONSOLE=y
CONFIG_FRAMEBUFFER_CONSOLE_DETECT_PRIMARY=y
CONFIG_FB=y
CONFIG_FB_SIMPLE=y
# Enable DRM framebuffer for iMX8MP
# CONFIG_DRM_FBDEV_EMULATION=y
# CONFIG_DRM_FBDEV_OVERALLOC=100
# Enable logo support - CRITICAL for splash display
CONFIG_LOGO=y
CONFIG_LOGO_LINUX_MONO=y
CONFIG_LOGO_LINUX_VGA16=y
CONFIG_LOGO_LINUX_CLUT224=y
# Disable printk but keep framebuffer
CONFIG_PRINTK=n
CONFIG_EARLY_PRINTK=n
# CONFIG_UBI_SILENCE_MSG=y
After these I still now didn’t see any logo on the kernel linux splash screen at start time only the blank screen is displayed. I need the help to fix this issue for device display screen developement.
Hi @ToradexAI,
Any update for this issue?
Hi @lucas_az.tx,
The Issue has been resolved, thanks for the help with the community.
Hi @lucas_az.tx,
Need to create the patch file inside the dev shell and then clone it to the recipes-bsp in the custom layer and then name file as given in the devshell. After that attach this file inside the u-boot-toradex_%.bbappend file to apply this config in the yocto build os image.
disable-console-logs.patch :
Index: git/include/configs/verdin-imx8mp.h
--- git.orig/include/configs/verdin-imx8mp.h
+++ git/include/configs/verdin-imx8mp.h
@@ -44,6 +44,7 @@
"fdt_board=dev\0" \
"initrd_addr=0x43800000\0" \
"initrd_high=0xffffffffffffffff\0" \
+ "tdxargs=console=null quiet loglevel=0 vt.global_cursor_default=0 vt.default_redraw=0 consoleblank=0\0" \
"update_uboot=askenv confirm Did you load flash.bin (y/N)?; " \
"if test \"$confirm\" = \"y\"; then " \
"setexpr blkcnt ${filesize} + 0x1ff && setexpr blkcnt " \
Hi @Hariprabhu_13!
Thanks for sharing! I’m sure it will help others with the same issue.
Best regards.
