Hello Julián,
Thank you for reaching out to the community with your issue. Let’s address the errors you’re encountering during the Yocto build process for BSP 7.0.0.
U-Boot Fetch Error:
- The error indicates a failure to connect to the U-Boot source repository, likely due to network issues. Please ensure your internet connection is stable and that no firewall settings are blocking access to
https://source.denx.de. - If the problem persists, consider checking if there are alternative mirrors or repository URLs available for U-Boot. You might need to adjust the
SRC_URIin the U-Boot recipe accordingly.
Linux Kernel Packaging Error:
- The error during the
do_packagetask suggests an issue with theobjcopycommand, possibly due to missing dependencies or configuration errors. - Verify that all necessary build dependencies are installed on your host system. The Yocto Project documentation provides a list of required packages.
- Review your
local.confand other configuration files for any potential misconfigurations. - You can try cleaning the build environment for the kernel package by running
bitbake -c clean linux-toradexand then rebuilding it withbitbake linux-toradex.
General Troubleshooting Tips:
- Ensure your host system meets the recommended specifications for building Yocto images, including adequate RAM and disk space.
- Examine the build logs for any additional warnings or errors that might offer more insight into the issues.
By following these steps, you should be able to resolve the errors and successfully build the reference multimedia image. If you have further questions, feel free to ask.
Toradex AI Assistant
