I understand your frustration with the sporadic build failures when git.toradex.com repositories become unavailable. This is indeed a known issue that affects Yocto builds when the primary repository sources are unreachable, even when local caches exist.
Current Repository Structure
Toradex maintains several BSP layers and repositories that are essential for building custom images (1). The main repositories include:
- toradex-manifest: Contains all layers used by Torizon OS and Reference Images
- meta-toradex-bsp-common: BSP layer common to all Toradex modules
- meta-toradex-nxp: BSP layer for NXP SoC-based modules
- meta-toradex-ti: BSP layer for Texas Instruments SoC-based modules
Workarounds for Repository Availability Issues
Based on community experiences, here are some approaches to mitigate this issue:
1. Alternative Repository Access Methods
Some users have found success using different protocols when the HTTPS access fails (2). You can try modifying your repository access to use:
git clone git://git.toradex.com/meta-toradex-bsp-common.git
Instead of the HTTPS variant that may be experiencing issues.
2. Local Repository Mirroring
While you mentioned maintaining internal mirrors, this remains one of the most robust solutions for production environments. You can:
- Clone the essential repositories locally during stable periods
- Modify your
local.confto point to your internal mirrors - Set up automated synchronization during maintenance windows
3. Yocto Build Configuration
Ensure your Yocto build configuration includes proper fallback mechanisms. The Yocto Project documentation suggests configuring multiple source URIs where possible (1).
Repository Status and Alternatives
The issue you’re experiencing appears to be related to temporary server availability problems (3). While there isn’t currently an official GitHub mirror for u-boot-toradex, the community has noted that such infrastructure improvements would benefit all users.
Recommendations
- Immediate Solution: Use the git:// protocol instead of HTTPS when accessing Toradex repositories
- Medium-term: Implement local mirroring for critical repositories in your build infrastructure
- Build Resilience: Configure your build system to retry failed downloads after a delay
Your suggestions for adding repository mirrors and improving the robustness of the build system are valuable feedback that would benefit the entire Toradex community. The current single point of failure does create unnecessary build interruptions for development teams.
