Yocto- Build Appliance
How to set network configuration while building image of buil-appliance in vmware workstation?
][1]
when i run “core-image-minimal” in workstation it is failling to fetch urls and also not pinging other ip’s.
How to build this successfully?
hello,
which branch of yocto build are you compiling?
Can you provide the hardware and software details of your build host?
Are you able to download this files manually using wget or ping any address like www.toradex.com?
yocto- poky (distro) master-branch. host machine -ubuntu 16.04. And I’m not able to do wget it is giving connection refused.
hello, can you do wget in the host without VM? If yes, then you need to talk to your Internet provider!
