Xen Implementation in apalis imx8quadmax of toradex
Hi ,
Currently implementing the xen hypervisor on imx8quadmax, Need support regarding this implentation and could you please share if any resources available regarding this.
I’d be glad to help! Could you let me know which OS and version you are using?
To provide the most accurate guidance for implementing Xen hypervisor on your iMX8 QuadMax, I need to understand your specific setup. Please share:
  • Which OS and version are you running on the device?
  • Are you using Torizon OS or a Yocto-based BSP?
You can use the tdx-info command to get detailed information about your system. More details about this command are available at: Getting Device Information with Tdx-Info | Toradex Developer Center
Current Status of Xen Support
Based on community discussions, there have been attempts to implement Xen on Apalis iMX8QM modules, but users have encountered challenges including kernel panic issues during boot(1). The community feedback suggests that Xen support on Toradex boards is not commonly implemented or officially supported(2).
Alternative Recommendation
For virtualization needs, I would recommend considering Torizon OS with containers instead, as this is fully supported by Toradex and provides excellent isolation and deployment capabilities for embedded applications.
Once you provide your OS version and specific setup details, I can offer more targeted guidance for your implementation.
Hi @naresh1!
I kindly ask that you not open new threads about the same topic. It makes our queue organization and prioritization more difficult.
I will close this thread, and the support will continue in the other one.
Best regards.
