Wrong initial value in /etc/timestamp on build
Is it possible that the format of the timestamp that is loaded to /etc/timestamp does not match what is expected in timestamp-service ?
I’m getting this failure:
Jan 04 20:33:10 xx systemd[1]: Started Timestamping service.
Jan 04 20:33:11 xx systemd[1]: Starting Timestamping service...
Jan 04 20:33:11 xx load-timestamp.sh[535]: Update systemtime from /etc/timestamp
Jan 04 20:33:11 xx load-timestamp.sh[535]: date: invalid date '0320105050201603'
Jan 04 20:33:11 xx systemd[1]: timestamp.service: main process exited, code=exited, status=1/FAILURE
I did not run this on a “Vanilla” Toradex version but I believe the bug should be there as well since this:
http://git.openembedded.org/openembedded-core/tree/meta/classes/image.bbclass?h=jethro#n468
Inserts a timestamp with seconds to /etc/timestamp but this:
Does the following:
SYSTEMDATE=$(/bin/date -u "+%4Y%2m%2d%2H%2M")
TIMESTAMP=$(/bin/cat /etc/timestamp 2>/dev/null)
if [ $SYSTEMDATE -lt $TIMESTAMP ] 2>/dev/null ; then
Expects /etc/timestamp without seconds.
Hi Gardar
You are right. Since we moved to V2.5 the initial format of /etc/timestamp was wrong resulting in the error you see.
It happend a few time already that someone thought it a good idea to change the data format in /etc/timestamp without patching alongside the angstrom systemd implementition of the poor man’s RTC.
I will send a patch to the meta-angstrom fixing that.
Thank you for reporting this and your excellent evaluation of why the error happens.
Max
