When creating a brand new application via the “Create C/C++ application”, I get the following error when (re)building the SDK:
[08-08 10:20:53.998] Internal server error
[08-08 10:20:53.998] Error (500) - [Errno 2] No such file or directory: '/home/hvex/.vscode/extensions/toradex.torizon-1.3.0/moses-linux/platforms/arm32v7-qt5-wayland-no-ssh_bullseye/sdk.dockerfile'
Indeed, I won’t have this file as I’m using the early access extension version 1.4.153 and don’t have the stable version of the extension installed. However, why is it requiring that file in the first place?
Even looking at the auto-generated files, I see only references to version 1.4.153. For example, the devcontainer.json file is
"name": "torizon_testscreen",
"dockerFile": "Dockerfile",
"extensions": [
"ms-vscode.cpptools"
"containerEnv": {},
"runArgs": [
"--network=host"
"remoteUser": "torizon",
"postCreateCommand": "mkdir -p /home/torizon/.vscode-server-insiders/extensions ; mkdir -p /home/torizon/.vscode-server/extensions; ln -s /home/torizon/.torizon-extension /home/torizon/.vscode-server-insiders/extensions/toradex.torizon ; ln -s /home/torizon/.torizon-extension /home/torizon/.vscode-server/extensions/toradex.torizon ; chgrp docker /var/run/docker.sock ; true",
"mounts": [
"source=${localEnv:HOME}${localEnv:USERPROFILE}/.moses,target=/home/torizon/.moses,type=bind",
"source=//var/run/docker.sock,target=/var/run/docker.sock,type=bind",
"source=/home/hvex/.vscode/extensions/toradex.torizon-early-access-1.4.153,target=/home/torizon/.torizon-extension,type=bind"
What must I change so that the correct version is targeted?
