Windows Embedded Compact Networking popup warning
We have an application on iMX6/WinEC7 from which network settings can be configured. If we set a host name or an IP address which is used in the network already there will be a popup warning from Windows (see attached images). We actually take care of returned errors in the source code but the Windows popups are triggered anyway. Is there a way to suppress the popup warnings?
Dear @widtmann
We implemented a registry setting to disable these popups.
[HKEY_LOCAL_MACHINE\Software\NETUI]
“SuppressPopups” = DWORD:1
For some more details, please refer to our developer page article
Regards, Andy
Just tested the registry key and it works. Brilliant support as always! Thanks.
