We are seeing an error when starting Windows CE in the Colibri iMX7D modules. When we start a module that has been disconnected for several hours, sometimes it does not start, it only shows the start screen but it does not go beyond this point. We have tested with version 1.2 and 1.3b2 and the problem persists, one of our clients has 30 modules and he tells us that some hardly fail and others every day first thing in the morning.
This problem is no longer new, when do you plan to fix it?
Is it possible to collect debug logs on serial debug port from failing modules? Please follow this article for instructions.
We continue with the same problem, and since it was not an error that occurred it was always difficult to capture the messages, but now we have a module in which it occurs more than in the others, and these are the messages:
When it starts:
Toradex Windows CE 7.0 1.3b2 for iMX7 Built Jul 31 2019
SMP support enabled
CPU0 started
CPU1 started
Port is used for OS debug!
Waiting for flash disk \FlashDisk for 300 seconds
Folder mounted
Loading ENET1…
Done ENET1
Ethernet: Disconnected
Loading Display driver…
Done Display driver
Invalid time on External RTC, please set a valid time
UnfdMutiTchDrv 2.0 loading…done
MultiTchHwAdapt loading…Warning: you are requesting
IOCTL_HAL_GET_DEVICE_INFO::SPI_GETPLATFORMTYPE, which has been deprecated. Use IOCTL_HAL_GET_DEVICE_INFO::SPI_GETPLATFORMNAME instead.
Warning: you are requesting IOCTL_HAL_GET_DEVICE_INFO::SPI_GETPLATFORMTYPE, which has been deprecated. Use IOCTL_HAL_GET_DEVICE_INFO::SPI_GETPLATFORMNAME instead.
MultiTchHwAdapt: restarts communication with touch controller…
Loading NETUI…
Done NETUI
And when it doesn’t start:
SMP support enabled
CPU0 started
CPU1 started
****And the bootloader break here
