Hi
- evnironment
I use on windows7 system,and instal VS2008 , VS2008 sp1 and wince7 PB , PB update online (select ARMV7 and x86 for virtual PC)
I use col evalution board v3.1a and col iMX6S 256MB IT V1.0 A
I can flash the downloaded image from toradex site ( Toradex Documents - iMX6 WinCE Image ) , the image works fine on col evalution board v3.1a
- failure
2.1
I download BSP ( Toradex Documents - iMX6 WinCE7 BSP ) and extract it.
copy TORADEXIMX6BIN into “C:\WINCE700\platform”.
2.2
I download workspace (Toradex Documents - iMX6 WinCE7 Workspace) and extract it.
copy IMX6_Core7 folder into “C:\WINCE700\OSDesigns”
2.3
In VS2008, menu File → Open → Project/Solution to open “C:\WINCE700\OSDesigns\IMX6_Core7\IMX6_Core7.sln”,
VS2008 popup below dialog message :
Platform Builder determined that the OS design you are opening contains configurations that reference board support packages that are not corrently installed.
and prompt me to remove list :
ToradexiMX6 ARMV7 debug
ToradexiMX6 release checked
2.3.1
it seems that I have not install ARMV7.
I double check that PB installer and confirm ARMV7 is installed.
in fact , I have not install ,ARMV6 (I only install ARMV7)
2.4
I skip the prompt and press OK.
2.5
I goto Solution Explorer pane, select “IMX6_Core7” , and right-click by mouse, it has not “build IMX6_Core7” and “rebuild IMX6_Core7” menu.(only has “clean IMX6_Core7” menu)
2.5.1
I check Catalog Items View pane:
IMX6_Core7 → Third Party->BSP → ToradexIMX6BIN: ARMV7
the checkbox is marked by red ''x" , it means it invalid.
2.5.2
in Catalog Items View pane, I goto IMX6_Core7->BSP
and check “BSP Template : ARMv7” , its checkbox is empty.
2.5.2.1
I select the checkbox of “BSP Template : ARMv7” ,
I can see checkbox of “BSP Template : ARMv7” is marked by green check.
and checkbos of IMX6_Core7 → Third Party->BSP → ToradexIMX6BIN: ARMV7 has not any changes.
2.5.2.2
I uncheck the checkbox of “BSP Template : ARMv7” again, it changes to empty. (uncheck state)
at the same time, I find that the checkbox of IMX6_Core7 → Third Party->BSP → ToradexIMX6BIN: ARMV7 is marked by green check automatically.
and the checkbox of IMX6_Core7 → Third Party->BSP → ToradexIMX6BIN: ARMV7 can not be unchecked.
2.6
I goto Solution Explorer pane, select “IMX6_Core7” , and right-click by mouse, it still has not “build IMX6_Core7” and “rebuild IMX6_Core7” menu.(only has “clean IMX6_Core7” menu)
2.6.1
when I check / uncheck checkbox of IMX6_Core7 → Third Party->BSP → ToradexIMX6BIN: ARMV7 for several times, the “build IMX6_Core7” and “rebuild IMX6_Core7” menu appears on “IMX6_Core7” of Solution explorer.
2.6.2
I rebuild solution.
the NK.bin is generated , but it is different with the one (download from toradex) , its size is 62M+.
flash it into device and restart, after image is loaded, No wince desktop.
it is same after I update registry as below:
[HKLM\init]
Launch50=explorer.exe
3 HELP
what should I do ? pls feedback as soon as possible. thanks.
if possible, it is best to mail : Tony.Shen@mt.com
