I have a new Colibri Evaluation Board V3.2A and VF61 256MB IT, now I have the problem that it won’t boot WinCE.
I use TeraTerm and get only Boot Message and the scren stays with it on.
Toradex Bootloader 1.2 for Colibri Built Sep 4 2015
CPU: MVF61 500 Mhz
Flash: 512 MB
RAM: 256 MB
Using ECC Type: 7
Booting from fuses.
Colibri VF61 module version 1.2A
Press [SPACE] to enter Bootloader Menu
Initiating image launch in 0 seconds.
Loading OS Image
Done.
OEMLaunch 80004000
What I can do? Is Win CE in Flash corrupt? or is something wronf with boards?
Thank You for answering.
Hi, can you please enter bootloader and enable debug output. Enable the debug messages | Toradex Developer Center
Paste the log here than and we will give you instructions how to fix this.
I’ve enabled debug and got at the end of booting following message:
IMAGE(CE6): 1.2 for Colibri Built Sep 4 2015
Registry - registry is empty.
Loading NAND…
Done NAND
The question is how to initialise and put registry on the board and have WInCE6 on the screen?
I’ve installed only image V1.2 and now works. Is it possible to leave bootloader V1.2 and to install only Version 1.3beta3 for WinCE? or is better to have both the same version?
No, you have to also update bootloader. You can just put it on sdcard enter the bootloader and type: flashloader
After reboot you will have new version of bootloader
OK, now it’s clear, always a new version of bootloader and image too. Thank You.
Can you please update to the latest version you can download from our website. VF50 / VF61 WEC Software | Toradex Developer Center
Same problem here. Have you found the solution?
can you please read trough all this posts and provide information I asked for. Like debug outputs etc. Also next time please open new question do not reopen old ones.
