Hi Team,
We are in process of redesign our board, we use iMX7d 1GB eMMC SOM.
Could you please help me share list of supported WiFi modules?
Thank you
Neeraj
Hi Team,
Thank you
Neeraj
Which modules are you talking about?
USB or SDIO Based?
Hi @jaski.tx ,
Looking for SDIO based. I already did lot of research earlier building different branch, backports drivers and what not but nothing worked.
My earlier testing / observations are:
https://www.toradex.com/community/questions/44146/how-to-enable-sdio-wifi-in-imx7.html?childToView=45433#comment-45433
https://www.toradex.com/community/questions/45141/how-to-enable-wireless-interface-on-kernel-30-imx7.html?childToView=45438#comment-45438
Somehow I do not see iMX7 in the list below: is WiFi not supported in this module or document is not updated?
Could you please tell me SDIO module which is already tested and running with Toradex kernel without any modification? Like the way I do for USB based at present.
Thank you
Neeraj
HI
So you were not able to deploy a custom kernel with backports and kernel modules?
Sure, iMX7 is supported for SDIO or USB Wifi Dongles. Lot of our customers are using this. This list shows especially SoM with already integrated Wifi chip, which could be a recommendable solution for you.
We have tested some of the SDIO modules, which should work out of box.
Thank you for details.
let me discuss with team and see if we can switch to iMX8.
Is there any document describing changes/comparison b/w iMX7d and iMX8? this will help us to take decision.
Thank you
Neeraj
You are welcome.
You can check this page and remove all the modules except iMX7 and iMX8.
