WIFI connection to network problems
Hi All,
We have a LM006 USB wifi dongle, and use it to connect to a company server.
When rebooting CE Sometimes the connection goes fast (4-5 seconds),
Sometimes the connection takes minutes or even stay disconnected
Occasional i have seen the connection is made but there is no access to the network folder.
All these tests are with the same settings (DHCP) and the same signal strength (Excellent).
To be sure the DHCP does not cause thisi i tried to setup my wifi settings to use a static IP, but when i do this in
“network and dial-up connections”, the moment i press the ok button in the IP settings page, the settings change by itself to DHCP.
my Questions
a) why is the time to connect sometimes much longer ?
b) how do i setup static IP for the wifi connection?
c) what can cause no network access , even while connection is ok?
Thank you :slight_smile:
Steve
Did you try to increase a PhysicalPageSize ([HKEY_LOCAL_MACHINE\Drivers\BuiltIn\OHCI]) ?
@Steve_elaut: Which version of WEC7 do have currently installed?
CE7,
i will try too increase PhysicalPageSize ,any other tips are welcome
thanks :slight_smile:
i can’t find this location : HKEY_LOCAL_MACHINE\Drivers\BuiltIn\OHCI
Where else can the PhysicalPageSize setting be?
