I installed a PCIe wifi to Apalis i.MX6D with Linux. The device and interface can be accessed.
root@apalis-imx6:~# ifconfig
wlp4s0 Link encap:Ethernet HWaddr 20:7C:8F:56:BC:DE
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
root@apalis-imx6:~# lspci
00:00.0 PCI bridge: Synopsys, Inc. Device abcd (rev 01)
01:00.0 PCI bridge: PLX Technology, Inc. PEX 8605 PCI Express 4-port Gen2 Switch (rev aa)
02:01.0 PCI bridge: PLX Technology, Inc. PEX 8605 PCI Express 4-port Gen2 Switch (rev aa)
02:02.0 PCI bridge: PLX Technology, Inc. PEX 8605 PCI Express 4-port Gen2 Switch (rev aa)
02:03.0 PCI bridge: PLX Technology, Inc. PEX 8605 PCI Express 4-port Gen2 Switch (rev aa)
04:00.0 Network controller: Qualcomm Atheros AR93xx Wireless Network Adapter (rev 01)
When I tried to connect WiFi with connman, it said “cfg80211: DFS Master region: unset” and failed to connect. Could it affect WiFi connectivity ?
connmanctl> agent on
Agent registered
connmanctl> connect wifi_207c8f56bcde_48414d455f41355f36326661_managed_psk
Agent RequestInput wifi_207c8f56bcde_48414d455f41355f36326661_managed_psk
Passphrase = [ Type=psk, Requirement=mandatory ]
Passphrase? 1234567
connmanctl> [ 94.781715] wlp4s0: authenticate with 9c:41:7c:36:2f:a8
[ 94.798098] wlp4s0: send auth to 9c:41:7c:36:2f:a8 (try 1/3)
[ 96.023843] wlp4s0: send auth to 9c:41:7c:36:2f:a8 (try 2/3)
[ 96.798590] wlp4s0: authenticated
[ 96.802616] ath9k 0000:04:00.0 wlp4s0: disabling HT/VHT due to WEP/TKIP use
[ 96.813919] wlp4s0: associate with 9c:41:7c:36:2f:a8 (try 1/3)
[ 98.053835] wlp4s0: associate with 9c:41:7c:36:2f:a8 (try 2/3)
[ 98.809213] wlp4s0: RX AssocResp from 9c:41:7c:36:2f:a8 (capab=0x431 status=0 aid=1)
[ 98.817331] wlp4s0: associated
[ 98.820503] IPv6: ADDRCONF(NETDEV_CHANGE): wlp4s0: link becomes ready
[ 103.584269] cfg80211: Calling CRDA to update world regulatory domain
[ 103.625214] cfg80211: World regulatory domain updated:
[ 103.630383] cfg80211: DFS Master region: unset
[ 103.634835] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 103.643228] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[ 103.650700] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[ 103.658128] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[ 103.665557] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[ 103.672959] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[ 103.680373] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm)
[ 103.688207] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[ 103.698456] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[ 103.710523] IPv6: ADDRCONF(NETDEV_UP): wlp4s0: link is not ready
Error /net/connman/service/wifi_207c8f56bcde_48414d455f41355f36326661_managed_psk: Operation aborted
connmanctl>
