WiFi client and BT at the same time on AW-CM276NF
Dear support team,
I’m trying to run a use-case where WiFi client and BT must run in parallel.
As you wrote on your help pages for Azurewave AW-CM276NF, this does not work with mwifiex driver from the Linux kernel, but with drivers from NXP.
Would it be possible to provide these drivers to me for further tests, to see if these can solve my problem?
Module: Colibri iMX6ULL 512MB Wi-Fi / Bluetooth V1.1A
Carrier board: Colibri Evaluation Board V3.2B
Linux BSP 5.4.0
Stefan
Hi @sraeck !
On the Azurewave AW-CM276NF Wi-Fi & Bluetooth module | Toradex Developer Center article, we state that for some use-cases, the mainline driver presents performance.
Have you tested the mwifiex driver for your use case?
