IS Wi-Fi /Blue Tooth activity LED on iMX6ULL 512MB WB IT active Low or Active High
hi @zecons
Could you provide the version of the hardware and software of your module? Which carrier board are you using?
We want to make a custom carrier board and on Linux OS
Hi @zecons
Thanks for the information. It seems that currently these pins are always high and not controlled by the firmware of the WiFi chip.
Do you absolutely need the functionality of having the activity LEDS on your carrier Board? If yes, could you give a timeline, when you need it?
Since these signals are shown in sodimm connector for the modules with wifi/blutooth we want to utilize them for showing the activity of teh respective interface if any
Hi @zecons
We will check internally for this Issue and come back to you within this week.
