Here is the dmesg log.
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 6.6.84-7.2.0-devel-g87bfb710b6f1 (oe-user@oe-host) (aarch64-tdx-linux-gcc (GCC) 13.3.0, GNU ld (GNU Binutils) 2.42.0.20240723) #1-Torizon SMP PREEMPT Mon Mar 31 08:47:48 UTC 2025
[ 0.000000] KASLR disabled due to lack of seed
[ 0.000000] Machine model: Toradex Verdin iMX8M Plus WB on Verdin Development Board
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created CMA memory pool at 0x00000000a0000000, size 512 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000a0000000..0x00000000bfffffff (524288 KiB) map reusable linux,cma
[ 0.000000] OF: reserved mem: 0x0000000000900000..0x000000000096ffff (448 KiB) nomap non-reusable ocram@900000
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000040000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x000000013fffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000040000000-0x000000013fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x000000013fffffff]
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.4
[ 0.000000] percpu: Embedded 29 pages/cpu s80040 r8192 d30552 u118784
[ 0.000000] pcpu-alloc: s80040 r8192 d30552 u118784 alloc=29*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] alternatives: applying boot alternatives
[ 0.000000] Kernel command line: root=LABEL=otaroot rootfstype=ext4 quiet logo.nologo vt.global_cursor_default=0 plymouth.ignore-serial-consoles splash fbcon=map:3 ostree=/ostree/boot.1/torizon/25e793cfce8d75f3366d0cbdf086cb12815074ce489eb19ef74a74eded8be9af/0
[ 0.000000] Unknown kernel command line parameters "splash ostree=/ostree/boot.1/torizon/25e793cfce8d75f3366d0cbdf086cb12815074ce489eb19ef74a74eded8be9af/0", will be passed to user space.
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1032192
[ 0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off
[ 0.000000] software IO TLB: area num 4.
[ 0.000000] software IO TLB: mapped [mem 0x00000000faa90000-0x00000000fea90000] (64MB)
[ 0.000000] Memory: 3480048K/4194304K available (15680K kernel code, 2966K rwdata, 6292K rodata, 4352K init, 605K bss, 189968K reserved, 524288K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 160 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] Root IRQ handler: gic_handle_irq
[ 0.000000] GICv3: GICv3 features: 16 PPIs
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000038880000
[ 0.000000] ITS: No ITS available, not enabling LPIs
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000000] arch_timer: cp15 timer(s) running at 8.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x1d854df40, max_idle_ns: 440795202120 ns
[ 0.000000] sched_clock: 56 bits at 8MHz, resolution 125ns, wraps every 2199023255500ns
[ 0.000577] Console: colour dummy device 80x25
[ 0.000587] printk: console [tty0] enabled
[ 0.000665] Calibrating delay loop (skipped), value calculated using timer frequency.. 16.00 BogoMIPS (lpj=80000)
[ 0.000679] pid_max: default: 32768 minimum: 301
[ 0.000807] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.000825] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.002320] RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
[ 0.002392] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
[ 0.002578] rcu: Hierarchical SRCU implementation.
[ 0.002583] rcu: Max phase no-delay instances is 1000.
[ 0.003667] EFI services will not be available.
[ 0.003955] smp: Bringing up secondary CPUs ...
[ 0.004430] Detected VIPT I-cache on CPU1
[ 0.004488] GICv3: CPU1: found redistributor 1 region 0:0x00000000388a0000
[ 0.004525] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 0.005051] Detected VIPT I-cache on CPU2
[ 0.005093] GICv3: CPU2: found redistributor 2 region 0:0x00000000388c0000
[ 0.005114] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[ 0.005600] Detected VIPT I-cache on CPU3
[ 0.005642] GICv3: CPU3: found redistributor 3 region 0:0x00000000388e0000
[ 0.005660] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[ 0.005733] smp: Brought up 1 node, 4 CPUs
[ 0.005746] SMP: Total of 4 processors activated.
[ 0.005754] CPU features: detected: 32-bit EL0 Support
[ 0.005758] CPU features: detected: CRC32 instructions
[ 0.005813] CPU: All CPU(s) started at EL2
[ 0.005817] alternatives: applying system-wide alternatives
[ 0.007589] devtmpfs: initialized
[ 0.019705] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.019729] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.033431] pinctrl core: initialized pinctrl subsystem
[ 0.034533] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.035356] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[ 0.035505] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.035700] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.036192] thermal_sys: Registered thermal governor 'step_wise'
[ 0.036197] thermal_sys: Registered thermal governor 'user_space'
[ 0.036201] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.036240] cpuidle: using governor menu
[ 0.036404] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.036483] ASID allocator initialised with 65536 entries
[ 0.036718] Serial: AMBA PL011 UART driver
[ 0.036774] imx mu driver is registered.
[ 0.036799] imx rpmsg driver is registered.
[ 0.046115] /soc@0: Fixed dependency cycle(s) with /soc@0/bus@30000000/efuse@30350000/unique-id@8
[ 0.046603] /soc@0/bus@30800000/i2c@30a50000/hdmi@48: Fixed dependency cycle(s) with /soc@0/bus@32c00000/mipi_dsi@32e60000
[ 0.046629] /soc@0/bus@30800000/i2c@30a50000/hdmi@48: Fixed dependency cycle(s) with /hdmi-connector
[ 0.046933] /soc@0/bus@32c00000/mipi_dsi@32e60000: Fixed dependency cycle(s) with /soc@0/bus@32c00000/lcd-controller@32e80000
[ 0.046973] /soc@0/bus@32c00000/mipi_dsi@32e60000: Fixed dependency cycle(s) with /soc@0/bus@30800000/i2c@30a50000/hdmi@48
[ 0.047051] /soc@0/bus@32c00000/lcd-controller@32e80000: Fixed dependency cycle(s) with /soc@0/bus@32c00000/mipi_dsi@32e60000
[ 0.047332] /soc@0/bus@30c00000/lcd-controller@32fc6000: Fixed dependency cycle(s) with /soc@0/bus@30c00000/hdmi@32fd8000
[ 0.047430] /soc@0/bus@30c00000/hdmi@32fd8000: Fixed dependency cycle(s) with /soc@0/bus@30c00000/lcd-controller@32fc6000
[ 0.047549] /soc@0/interrupt-controller@38800000: Fixed dependency cycle(s) with /soc@0/interrupt-controller@38800000
[ 0.049760] /soc@0/bus@30000000/pinctrl@30330000: Fixed dependency cycle(s) with /soc@0/bus@30000000/pinctrl@30330000/gpio-qspi-pins
[ 0.050332] imx8mp-pinctrl 30330000.pinctrl: initialized IMX pinctrl driver
[ 0.050971] /soc@0/bus@30000000/efuse@30350000: Fixed dependency cycle(s) with /soc@0/bus@30000000/clock-controller@30380000
[ 0.052114] /soc@0/bus@30000000/efuse@30350000: Fixed dependency cycle(s) with /soc@0/bus@30000000/clock-controller@30380000
[ 0.055029] /soc@0/bus@30800000/i2c@30a50000/hdmi@48: Fixed dependency cycle(s) with /soc@0/bus@32c00000/mipi_dsi@32e60000
[ 0.055058] /soc@0/bus@30800000/i2c@30a50000/hdmi@48: Fixed dependency cycle(s) with /hdmi-connector
[ 0.058559] /soc@0/bus@30800000/i2c@30a50000/hdmi@48: Fixed dependency cycle(s) with /soc@0/bus@32c00000/mipi_dsi@32e60000
[ 0.058588] /soc@0/bus@30800000/i2c@30a50000/hdmi@48: Fixed dependency cycle(s) with /hdmi-connector
[ 0.061120] /soc@0/bus@32c00000/mipi_dsi@32e60000: Fixed dependency cycle(s) with /soc@0/bus@32c00000/lcd-controller@32e80000
[ 0.061163] /soc@0/bus@32c00000/mipi_dsi@32e60000: Fixed dependency cycle(s) with /soc@0/bus@30800000/i2c@30a50000/hdmi@48
[ 0.061283] /soc@0/bus@32c00000/lcd-controller@32e80000: Fixed dependency cycle(s) with /soc@0/bus@32c00000/mipi_dsi@32e60000
[ 0.061537] /soc@0/bus@30800000/i2c@30a50000/hdmi@48: Fixed dependency cycle(s) with /soc@0/bus@32c00000/mipi_dsi@32e60000
[ 0.061628] /soc@0/bus@32c00000/mipi_dsi@32e60000: Fixed dependency cycle(s) with /soc@0/bus@32c00000/lcd-controller@32e80000
[ 0.061663] /soc@0/bus@32c00000/mipi_dsi@32e60000: Fixed dependency cycle(s) with /soc@0/bus@30800000/i2c@30a50000/hdmi@48
[ 0.061893] /soc@0/bus@32c00000/mipi_dsi@32e60000: Fixed dependency cycle(s) with /soc@0/bus@32c00000/lcd-controller@32e80000
[ 0.061998] /soc@0/bus@32c00000/lcd-controller@32e80000: Fixed dependency cycle(s) with /soc@0/bus@32c00000/mipi_dsi@32e60000
[ 0.063890] /soc@0/bus@30c00000/lcd-controller@32fc6000: Fixed dependency cycle(s) with /soc@0/bus@30c00000/hdmi@32fd8000
[ 0.063973] /soc@0/bus@30c00000/hdmi@32fd8000: Fixed dependency cycle(s) with /soc@0/bus@30c00000/lcd-controller@32fc6000
[ 0.066154] /soc@0/bus@30c00000/lcd-controller@32fc6000: Fixed dependency cycle(s) with /soc@0/bus@30c00000/hdmi@32fd8000
[ 0.066512] /soc@0/bus@30c00000/lcd-controller@32fc6000: Fixed dependency cycle(s) with /soc@0/bus@30c00000/hdmi@32fd8000
[ 0.066612] /soc@0/bus@30c00000/hdmi@32fd8000: Fixed dependency cycle(s) with /soc@0/bus@30c00000/lcd-controller@32fc6000
[ 0.074485] Modules: 25264 pages in range for non-PLT usage
[ 0.074497] Modules: 516784 pages in range for PLT usage
[ 0.075264] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.075275] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[ 0.075281] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.075285] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[ 0.075292] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.075299] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[ 0.075306] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.075312] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[ 0.075771] cryptd: max_cpu_qlen set to 1000
[ 0.077941] iommu: Default domain type: Translated
[ 0.077949] iommu: DMA domain TLB invalidation policy: strict mode
[ 0.078286] SCSI subsystem initialized
[ 0.078542] libata version 3.00 loaded.
[ 0.078718] usbcore: registered new interface driver usbfs
[ 0.078749] usbcore: registered new interface driver hub
[ 0.078782] usbcore: registered new device driver usb
[ 0.080059] mc: Linux media interface: v0.10
[ 0.080095] videodev: Linux video capture interface: v2.00
[ 0.080162] pps_core: LinuxPPS API ver. 1 registered
[ 0.080167] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.080184] PTP clock support registered
[ 0.080465] scmi_core: SCMI protocol bus registered
[ 0.080779] Advanced Linux Sound Architecture Driver Initialized.
[ 0.081548] Bluetooth: Core ver 2.22
[ 0.081572] NET: Registered PF_BLUETOOTH protocol family
[ 0.081579] Bluetooth: HCI device and connection manager initialized
[ 0.081586] Bluetooth: HCI socket layer initialized
[ 0.081592] Bluetooth: L2CAP socket layer initialized
[ 0.081604] Bluetooth: SCO socket layer initialized
[ 0.082405] clocksource: Switched to clocksource arch_sys_counter
[ 0.082717] VFS: Disk quotas dquot_6.6.0
[ 0.082747] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.090324] NET: Registered PF_INET protocol family
[ 0.090503] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.093366] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[ 0.093411] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.093423] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.093636] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[ 0.094536] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.094642] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.094734] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.094964] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.095341] RPC: Registered named UNIX socket transport module.
[ 0.095348] RPC: Registered udp transport module.
[ 0.095351] RPC: Registered tcp transport module.
[ 0.095355] RPC: Registered tcp-with-tls transport module.
[ 0.095358] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.095369] PCI: CLS 0 bytes, default 64
[ 0.095683] Trying to unpack rootfs image as initramfs...
[ 0.785703] Freeing initrd memory: 12820K
[ 0.872506] Initialise system trusted keyrings
[ 0.872716] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 0.873202] NFS: Registering the id_resolver key type
[ 0.873239] Key type id_resolver registered
[ 0.873246] Key type id_legacy registered
[ 0.873263] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.873268] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 0.907214] NET: Registered PF_ALG protocol family
[ 0.907230] Key type asymmetric registered
[ 0.907235] Asymmetric key parser 'x509' registered
[ 0.907272] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[ 0.907379] io scheduler mq-deadline registered
[ 0.907385] io scheduler kyber registered
[ 0.907407] io scheduler bfq registered
[ 0.920815] mxs-dma 33000000.dma-apbh: initialized
[ 0.921611] SoC: i.MX8MP revision 1.1
[ 0.922004] Bus freq driver module loaded
[ 0.980408] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[ 0.984480] 30860000.serial: ttymxc0 at MMIO 0x30860000 (irq = 15, base_baud = 1500000) is a IMX
[ 0.985270] 30880000.serial: ttymxc2 at MMIO 0x30880000 (irq = 16, base_baud = 1500000) is a IMX
[ 0.985288] imx-uart 30880000.serial: Console IMX rounded baud rate from 114286 to 114300
[ 0.985318] printk: console [ttymxc2] enabled
[ 0.986248] 30890000.serial: ttymxc1 at MMIO 0x30890000 (irq = 17, base_baud = 1500000) is a IMX
[ 0.986974] 30a60000.serial: ttymxc3 at MMIO 0x30a60000 (irq = 18, base_baud = 1500000) is a IMX
[ 0.987113] serial serial0: tty port ttymxc3 registered
[ 1.004744] brd: module loaded
[ 1.009404] loop: module loaded
[ 1.009867] zram: Added device: zram0
[ 1.014838] usbcore: registered new interface driver usb-storage
[ 1.014906] usbcore: registered new interface driver usbserial_generic
[ 1.014932] usbserial: USB Serial support registered for generic
[ 1.015547] input: 30370000.snvs:snvs-powerkey as /devices/platform/soc@0/30000000.bus/30370000.snvs/30370000.snvs:snvs-powerkey/input/input0
[ 1.017204] snvs_rtc 30370000.snvs:snvs-rtc-lp: registered as rtc1
[ 1.017369] i2c_dev: i2c /dev entries driver
[ 1.022106] sdhci: Secure Digital Host Controller Interface driver
[ 1.022118] sdhci: Copyright(c) Pierre Ossman
[ 1.022422] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.025374] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.026260] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[ 1.027380] caam 30900000.crypto: device ID = 0x0a16040100000100 (Era 9)
[ 1.027398] caam 30900000.crypto: job rings = 2, qi = 0
[ 1.032998] caam algorithms registered in /proc/crypto
[ 1.033160] caam 30900000.crypto: caam pkc algorithms registered in /proc/crypto
[ 1.033183] caam 30900000.crypto: rng crypto API alg registered prng-caam
[ 1.033193] caam 30900000.crypto: registering rng-caam
[ 1.036031] Device caam-keygen registered
[ 1.038350] hid: raw HID events driver (C) Jiri Kosina
[ 1.038470] usbcore: registered new interface driver usbhid
[ 1.038476] usbhid: USB HID core driver
[ 1.039884] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 1.041170] cs_system_cfg: CoreSight Configuration manager initialised
[ 1.042139] /soc@0: Fixed dependency cycle(s) with /soc@0/bus@30000000/efuse@30350000
[ 1.045045] hantrodec 0 : module inserted. Major = 239
[ 1.045530] hantrodec 1 : module inserted. Major = 239
[ 1.045948] random: crng init done
[ 1.046412] hantroenc: HW at base <0000000038320000> with ID <0x80006200>
[ 1.046543] hx280enc: module inserted. Major <238>
[ 1.047769] usbcore: registered new interface driver snd-usb-audio
[ 1.049269] NET: Registered PF_INET6 protocol family
[ 1.050239] Segment Routing with IPv6
[ 1.050265] In-situ OAM (IOAM) with IPv6
[ 1.050328] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 1.050786] NET: Registered PF_PACKET protocol family
[ 1.050807] Key type dns_resolver registered
[ 1.050935] NET: Registered PF_VSOCK protocol family
[ 1.058155] mmc2: SDHCI controller on 30b60000.mmc [30b60000.mmc] using ADMA
[ 1.060252] registered taskstats version 1
[ 1.060369] Loading compiled-in X.509 certificates
[ 1.066504] Key type .fscrypt registered
[ 1.066518] Key type fscrypt-provisioning registered
[ 1.079408] gpio gpiochip0: Static allocation of GPIO base is deprecated, use dynamic allocation.
[ 1.081126] gpio gpiochip1: Static allocation of GPIO base is deprecated, use dynamic allocation.
[ 1.082505] gpio gpiochip2: Static allocation of GPIO base is deprecated, use dynamic allocation.
[ 1.084713] gpio gpiochip3: Static allocation of GPIO base is deprecated, use dynamic allocation.
[ 1.086490] gpio gpiochip4: Static allocation of GPIO base is deprecated, use dynamic allocation.
[ 1.089073] reg-fixed-voltage regulator-force-sleep-moci: nonexclusive access to GPIO for (null)
[ 1.090863] i2c i2c-0: using pinctrl states for GPIO recovery
[ 1.093985] rtc-ds1307 0-0032: registered as rtc0
[ 1.095164] rtc-ds1307 0-0032: setting system clock to 2025-08-29T12:08:54 UTC (1756469334)
[ 1.095781] at24 0-0050: supply vcc not found, using dummy regulator
[ 1.096404] at24 0-0050: 256 byte 24c02 EEPROM, writable, 16 bytes/write
[ 1.096446] i2c i2c-0: IMX I2C adapter registered
[ 1.097462] i2c i2c-1: using pinctrl states for GPIO recovery
[ 1.097580] i2c i2c-1: IMX I2C adapter registered
[ 1.098378] i2c i2c-2: using pinctrl states for GPIO recovery
[ 1.098419] i2c i2c-2: IMX I2C adapter registered
[ 1.099240] i2c i2c-3: using pinctrl states for GPIO recovery
[ 1.099710] pca953x 3-0021: using no AI
[ 1.099949] pca953x 3-0021: failed writing register
[ 1.105493] /soc@0/bus@32c00000/mipi_dsi@32e60000: Fixed dependency cycle(s) with /soc@0/bus@30800000/i2c@30a50000/hdmi@48
[ 1.105577] /hdmi-connector: Fixed dependency cycle(s) with /soc@0/bus@30800000/i2c@30a50000/hdmi@48
[ 1.105718] /soc@0/bus@30800000/i2c@30a50000/hdmi@48: Fixed dependency cycle(s) with /soc@0/bus@32c00000/mipi_dsi@32e60000
[ 1.105793] /soc@0/bus@30800000/i2c@30a50000/hdmi@48: Fixed dependency cycle(s) with /hdmi-connector
[ 1.106371] at24 3-0050: supply vcc not found, using dummy regulator
[ 1.106738] mmc2: new HS400 Enhanced strobe MMC card at address 0001
[ 1.107339] mmcblk2: mmc2:0001 IX2932 29.1 GiB
[ 1.107487] at24 3-0050: 256 byte 24c02 EEPROM, writable, 16 bytes/write
[ 1.107754] at24 3-0057: supply vcc not found, using dummy regulator
[ 1.108648] nxp-pca9450 0-0025: pca9450bc probed.
[ 1.108740] mmcblk2: p1
[ 1.109211] mmcblk2boot0: mmc2:0001 IX2932 4.00 MiB
[ 1.110171] mmcblk2boot1: mmc2:0001 IX2932 4.00 MiB
[ 1.111016] mmcblk2rpmb: mmc2:0001 IX2932 4.00 MiB, chardev (242:0)
[ 1.136103] i2c i2c-3: IMX I2C adapter registered
[ 1.147923] imx-cpufreq-dt imx-cpufreq-dt: cpu speed grade 7 mkt segment 2 supported-hw 0x80 0x4
[ 1.151992] sdhci-esdhc-imx 30b50000.mmc: Got CD GPIO
[ 1.156871] input: gpio-keys as /devices/platform/gpio-keys/input/input1
[ 1.157364] clk: Disabling unused clocks
[ 1.161194] ALSA device list:
[ 1.161205] No soundcards found.
[ 1.183041] mmc0: SDHCI controller on 30b40000.mmc [30b40000.mmc] using ADMA
[ 1.263294] mmc0: new ultra high speed SDR104 SDIO card at address 0001
[ 1.294013] mmc1: SDHCI controller on 30b50000.mmc [30b50000.mmc] using ADMA
[ 1.364398] Freeing unused kernel memory: 4352K
[ 1.364527] Run /init as init process
[ 1.364534] with arguments:
[ 1.364540] /init
[ 1.364544] splash
[ 1.364549] with environment:
[ 1.364553] HOME=/
[ 1.364558] TERM=linux
[ 1.364562] ostree=/ostree/boot.1/torizon/25e793cfce8d75f3366d0cbdf086cb12815074ce489eb19ef74a74eded8be9af/0
