Does anyone know which release of the Boot2Qt manifests for Yocto corresponds with the BSP2.8 version of the Toradex kernel?
Deficiencies with the BSP5 kernel + iMX M4 interaction are forcing me to fall back to 4.9 to see if I can get something to work. Qt doesn’t track Toradex releases so I’m hoping Toradex did. Thanks.
Hi @lkoziarz,
There’s not necessarily a “correspondence” as Boot2Qt is built with a BSP totally handled by Qt itself.
If you need to stay with an LTS release, I would recommend you to stay with our BSP 3.0.4.
About Boot2Qt, one of their latest releases was 5.15.2. It’s not working fine for you?
André Curvello
The Qt/Yocto manifests (https://code.qt.io/cgit/yocto/boot2qt-manifest.git/tree/) pick up various commits in the meta-toradex-nxp repository, so there’s a correspondence in there somewhere.
Qt 5.15.x is working just fine, I need a kernel that can support FreeRTOS on the M4 running simultaneously with Linux. There are other threads here covering that issue, @gustavo.tx can point you to them.
Hi @lkoziarz,
I’m checking that internally to be sure.
As soon as I have a position about it, I’ll provide you feedback here.
André Curvello
