Where is update.sh
Hi
I would like to copy the yocto image to mmc.
I refer to the following site
Where is the update.sh file?
Thanks.
Thank you.
You are welcome.
  • angstrom-lxde-image
update.sh is in Apalis-iMX6_LXDE-Image_2.8b4-20181029.tar.bz2
  • boot2qt isn’t
I did copy and modify update.sh .
It works well.
Did you try if you can flash boot2qt image using Toradex Easy Installer?
I did at u-boot
 1.  sdcard prepare
$ sudo fdisk /dev/sda ( one partition made )
$ sudo mkfs.fat /dev/sda1
$ sudo mount /dev/sdb1 /mnt/
2. file copy to update dectory
$ cd /build/oe-core/build-apalis-imx6/tmp/deploy/images/apalis-imx6
$ sudo cp flash_blk.img /build/oe-core/Apalis-iMX6_LXDE-Image_2.8.4/apalis-imx6_bin/
$ sudo cp flash_eth.img /build/oe-core/Apalis-iMX6_LXDE-Image_2.8.4/apalis-imx6_bin/
$ sudo cp fwd_blk.img /build/oe-core/Apalis-iMX6_LXDE-Image_2.8.4/apalis-imx6_bin/
$ sudo cp fwd_eth.img /build/oe-core/Apalis-iMX6_LXDE-Image_2.8.4/apalis-imx6_bin/
$ sudo cp fwd_mmc.img /build/oe-core/Apalis-iMX6_LXDE-Image_2.8.4/apalis-imx6_bin/
$ sudo cp SPL /build/oe-core/Apalis-iMX6_LXDE-Image_2.8.4/apalis-imx6_bin/
$ sudo cp -af u-boot* /build/oe-core/Apalis-iMX6_LXDE-Image_2.8.4/apalis-imx6_bin/
$ sudo cp -af uImage* /build/oe-core/Apalis-iMX6_LXDE-Image_2.8.4/apalis-imx6_bin/
$ sudo cp b2qt-embedded-qt5-image-apalis-imx6-20181114072344.rootfs.tar.xz /build/oe-core/Apalis-iMX6_LXDE-Image_2.8.4/
 - uncompress rootfs
$ cd /build/oe-core/Apalis-iMX6_LXDE-Image_2.8.4/
$ sudo mkdir rootfs
$ cd rootfs/
$ sudo tar xf ../b2qt-embedded-qt5-image-apalis-imx6-20181114072344.rootfs.tar.xz
3. update.sh modify
KERNEL_IMAGETYPE="uImage"
U_BOOT_BINARY=u-boot.imx-spl
4. Run update.sh
 $ sudo ./update.sh -m 1 -o /mnt/
    Apalis iMX6 rootfs specified
    Creating MBR file and do the partitioning
    0+0 records in
    0+0 records out
    0 bytes copied, 0.000118009 s, 0.0 kB/s
    Model:  (file)
    Disk /build/oe-core/Apalis-iMX6_LXDE-Image_2.8.4/apalis-imx6_bin/mbr.bin: 7168000s
    Sector size (logical/physical): 512B/512B
    Partition Table: msdos
    Disk Flags:
    Number  Start   End       Size      Type     File system  Flags
     1      8192s   40959s    32768s    primary               lba
     2      40960s  7127039s  7086080s  primary
    Creating VFAT partition image with the kernel
    mkfs.fat 3.0.28 (2015-05-16)
    mkfs.fat: warning - lowercase labels might not work properly with DOS or Windows
    Creating rootfs partition image
    981+0 records in
    981+0 records out
    1028653056 bytes (1.0 GB, 981 MiB) copied, 0.513367 s, 2.0 GB/s
    mke2fs 1.42.13 (17-May-2015)
    Discarding device blocks: done
    Creating filesystem with 251136 4k blocks and 62848 inodes
    Filesystem UUID: 30b3948d-747e-4e15-9c70-d23069067f28
    Superblock backups stored on blocks:
            32768, 98304, 163840, 229376
    Allocating group tables: done
    Writing inode tables: done
    Creating journal (4096 blocks): done
    Writing superblocks and filesystem accounting information: done
    tune2fs 1.42.13 (17-May-2015)
    Setting maximal mount count to -1
    Setting interval between checks to 0 seconds
    Successfully copied data to target folder.
    To flash the Apalis/Colibri iMX6 module a running U-Boot is required. Boot the
    module to the U-Boot prompt and
    insert the SD card, USB flash drive or when using TFTP connect Ethernet only
    and enter:
    'run setupdate'
    then to update all components enter:
    'run update'
    to update a single component enter one of:
    'run update_uboot'
    'run update_kernel'
    'run update_fdt'
    'run update_rootfs'
    If you don't have a working U-Boot anymore, connect your PC to the module's USB
    client port, bring the module in the serial download mode and start the
    update.sh script with the -d option. This will copy U-Boot into the modules RAM
    and execute it.
$ sudo umount /mnt
update at u-boot
U-Boot 2016.11-2.7.5+g52259cf (Oct 30 2018 - 12:04:57 +0900)
CPU:   Freescale i.MX6Q rev1.5 at 792 MHz
Reset cause: POR
I2C:   ready
DRAM:  1 GiB
PMIC:  device id: 0x10, revision id: 0x21, programmed
MMC:   FSL_SDHC: 0, FSL_SDHC: 1, FSL_SDHC: 2
auto-detected panel vga-rgb
Display: vga-rgb (640x480)
In:    serial
Out:   serial
Err:   serial
Model: Toradex Apalis iMX6 Quad 1GB V1.1B, Serial# 05196439
Net:   using PHY at 7
FEC [PRIME]
Apalis iMX6 # run setupdate
reading flash_blk.img
710 bytes read in 16 ms (43 KiB/s)
## Executing script at 12000000
reading apalis_imx6/flash_blk.img
4184 bytes read in 23 ms (176.8 KiB/s)
enter "run update" to update the entire module
Apalis iMX6 # run update_uboot
reading apalis_imx6/u-boot.imx-spl
371440 bytes read in 45 ms (7.9 MiB/s)
switch to partitions #1, OK
mmc0(part 1) is current device
MMC write: dev # 0, block # 138, count 726 ... 726 blocks written: OK
Fuse 0, 5:     5072
Fast boot mode already fused, no need to fuse
Apalis iMX6 # run update_kernel
reading apalis_imx6/uImage
5550288 bytes read in 295 ms (17.9 MiB/s)
writing uImage
5550288 bytes written
Apalis iMX6 # run update_fdt
reading apalis_imx6/imx6q-apalis-ixora-v1.1.dtb
49743 bytes read in 32 ms (1.5 MiB/s)
writing imx6q-apalis-ixora-v1.1.dtb
49743 bytes written
Apalis iMX6 # run update_3
reading apalis_imx6/root.ext4-100
67108864 bytes read in 3637 ms (17.6 MiB/s)
switch to partitions #0, OK
MMC write: dev # 0, block # 40960, count 131072 ... 131072 blocks written: OK
reading apalis_imx6/root.ext4-101
67108864 bytes read in 3506 ms (18.3 MiB/s)
MMC write: dev # 0, block # 172032, count 131072 ... 131072 blocks written: OK
reading apalis_imx6/root.ext4-102
67108864 bytes read in 3779 ms (16.9 MiB/s)
MMC write: dev # 0, block # 303104, count 131072 ... 131072 blocks written: OK
reading apalis_imx6/root.ext4-103
67108864 bytes read in 3568 ms (17.9 MiB/s)
MMC write: dev # 0, block # 434176, count 131072 ... 131072 blocks written: OK
reading apalis_imx6/root.ext4-104
67108864 bytes read in 3727 ms (17.2 MiB/s)
MMC write: dev # 0, block # 565248, count 131072 ... 131072 blocks written: OK
reading apalis_imx6/root.ext4-105
67108864 bytes read in 3453 ms (18.5 MiB/s)
MMC write: dev # 0, block # 696320, count 131072 ... 131072 blocks written: OK
reading apalis_imx6/root.ext4-106
67108864 bytes read in 3408 ms (18.8 MiB/s)
MMC write: dev # 0, block # 827392, count 131072 ... 131072 blocks written: OK
reading apalis_imx6/root.ext4-107
67108864 bytes read in 3415 ms (18.7 MiB/s)
MMC write: dev # 0, block # 958464, count 131072 ... 131072 blocks written: OK
reading apalis_imx6/root.ext4-108
67108864 bytes read in 3497 ms (18.3 MiB/s)
MMC write: dev # 0, block # 1089536, count 131072 ... 131072 blocks written: OK
reading apalis_imx6/root.ext4-109
67108864 bytes read in 3488 ms (18.3 MiB/s)
MMC write: dev # 0, block # 1220608, count 131072 ... 131072 blocks written: OK
reading apalis_imx6/root.ext4-110
67108864 bytes read in 3339 ms (19.2 MiB/s)
MMC write: dev # 0, block # 1351680, count 131072 ... 131072 blocks written: OK
reading apalis_imx6/root.ext4-111
67108864 bytes read in 3446 ms (18.6 MiB/s)
MMC write: dev # 0, block # 1482752, count 131072 ... 131072 blocks written: OK
reading apalis_imx6/root.ext4-112
67108864 bytes read in 3548 ms (18 MiB/s)
MMC write: dev # 0, block # 1613824, count 131072 ... 131072 blocks written: OK
reading apalis_imx6/root.ext4-113
MMC write: dev # 0, block # 1744896, count 131072 ... 131072 blocks written: OK
reading apalis_imx6/root.ext4-114
67108864 bytes read in 3404 ms (18.8 MiB/s)
MMC write: dev # 0, block # 1875968, count 131072 ... 131072 blocks written: OK
reading apalis_imx6/root.ext4-115
22020096 bytes read in 1138 ms (18.5 MiB/s)
MMC write: dev # 0, block # 2007040, count 43008 ... 43008 blocks written: OK
Apalis iMX6 #
hi @LEEBAK
Which Yocto image are you talking about? Did you create the image yourself? If yes, then you should find Apalis-iMX6_type_Image_XX.bz2 file in the deploy folder, type name stands for the type of image you built (LXDE, Console, Qt, …). The file update.sh is included in the .bz2 file.
You can find regular Bsp builds here.
Best regards, Jaski
