Using WEC 7.0, Colibri T30 with USB configured for the SD card visible externally as a mass storage device:
Is it possible to configure it to be writable by an application when the USB is not active and the SD_CARD is available internally, but read only to an external PC, when visible externally via USB as a mass storage devcice ?
This is to protect files on the device so that they cannot be altered or deleted from the external PC.
