When agpio access with apalis mx6q error problem
280-error-of-gpio.png][1]
hi sir,
when we acess the apalis controler mx6q board .the program will deploy completly in apalis hardware board but when we connect windows mobile connect below problems.so plz let me know what is problem as per as possible .Apalis IMx6q 2GB IT V1.1B(TORADEX FAMILY)
What OS version are you using?
From your screenshot it seems that Visual Studio crashed, but it would be useful to understand the sequence of operations you performed before the crash, so we may try to reproduce it.
If you just connect to your device using mobile device center (browsing files etc.) with no VS involved, do you get any exception?
Since you are working on a .NET application, please consider that you have to install the .NET Compact Framework on your target, following the instructions you can find here:
http://developer.toradex.com/knowledge-base/.net-compact-framework-flash-installer
